10-10-2017, 08:52 PM | #1 |
Going bonkers! Icebear zodiac
OK, first things first let me explain the problem:
Several weeks ago my wife and I set out on a picture perfect late evening sunset ride. 2 miles down the road her Icebear Zodiac rolled to a hault. It will sit there and idle perfect. The moment you give it virtually any throttle at all, it dies. So I had to tow it back home. I was told "main jet stopped up". Sounds reasonable. So knowing I wanted a tuneable carb anyways, I ordered a new Klein CV carb copy. Installed new carb, exact same results. :-/ Then I was told by several people "replace the CDI !!! " So I did. NADA! Same results. Then I was told " replace this & this & that " Long story shortened, It now has NEW carb, CDI, Ign. Coil, fuel pump, fuel lines (again) fuel filter (again), pulled and cleaned the NEW carb (just in case), new spark plug, new stator (thinking the ign. pickup thingy attached to the stator went bad. ), new vaccume lines (again), quadruple checked the intake boot & o-ring gasket. NOTHING has made any difference. Starts right up...........idles PERFECT and will sit there at idle for 20 min and never skip a beat. The second I roll on the throttle................it dies. There is NOTHING left to replace! Like, nothing! I have spent over $300 trying to fix this ghost problem! If it had full coverage, it may have found it's way into the bottom of KY Lake! hahahahaha! ( I would never actually do that ) Anyone have any other clue or have ever had a problem like this before?
" If it ain't broke, I can probably still fix it!" ---- Tim Allen |
10-10-2017, 10:20 PM | #2 |
Turn the choke off...sorry I know I'm not helping.
10-10-2017, 10:25 PM | #3 |
hahahahahaha!!!! :-P
10-10-2017, 10:32 PM | #4 |
You didn't mention anything about the battery. Test it to make sure it's good. Yep, a weak battery will allow the bike to start and idle but that's it.
Quote from weldangrind; You need a healthy battery to run a modern street bike, because the magneto can't provide enough power for spark and the always-on headlight. On my atv, I can run with a virtually dead battery, because I can switch the headlight off.
10-10-2017, 11:13 PM | #5 |
No mention of checking valve clearance?
Potentially related orientation issue with the 2-bolt intake valve cover. Last edited by tortoise; 10-10-2017 at 11:48 PM. |
