Old 10-10-2017, 11:55 AM   #1
houstad   houstad is offline
Hammer 200cc
I just put together my new Hammer 200cc, looks just like a taotao bull. I have no idea who makes it. My issue is it is very hard to steer. What needs to be done to loosen it up?
Thanks for the help
Old 10-10-2017, 12:53 PM   #2
Just grease up all the steering components.
2004 Honda ST 1300
Old 10-10-2017, 02:01 PM   #3
How is the steering shaft clamped to the frame? Can you show us?
Old 10-12-2017, 10:52 PM   #4
I will get pics up soon.
Old 10-13-2017, 07:10 PM   #5
steering
try to ;oosen the spindle bolts to the a arms mounts.. back off the tie rods nuts... just alittle... and put the cotter pins back in.. if everything is real good and tight... then it becomes hard to turn,.,.. I have done this when assembling KIDS ATV... AND THEN THEY ARE TOO WEAK TO TURN.. have the stuff... just alittle loose... but nnot loose.. you know what I mean..
ABIBABA ATV ETC
Old 04-23-2018, 09:19 AM   #6
Well since the last post in October. I loosened things up. I took it out to the ATV park and rode it. With use it has loosened up. It has been in storage for the winter. Now that it is out again It does not want to stay in forward, It is slipping. is there a clutch adjustment? It has less than 3 hours on it.
Old 06-20-2018, 04:47 PM   #7
It has loosens up as time has gone on.
Old 06-21-2018, 02:41 PM   #8
clutch
is it the linkage adjust ment...??? or clutch slipping... look on youtube for clutch adjustment on 50 cc Honda... I would think it is jumping out of gear... not going fully in gear... so check your adjustment
ABIBABA ATV ETC
Old 01-02-2019, 11:01 PM   #9
I adjusted the area that connects the shifter linkage to the engine area. Everything was loose and need adjusting now it works great.
