09-26-2017, 11:24 AM | #1 |
Need help identifying ATV and ignition coil
Hello –
Newbie to the forum here. Was referred by VMC parts. I’m searching for an ignition coil for a 50cc 2 stroke that has lost its spark. Here is what I know:
My thoughts are it has to be the ignition coil or the magnets since the stator is new. Hopefully someone can lead me in the right direction. |
09-26-2017, 01:39 PM | #2 |
Is your new stator working? Getting voltage when the engine turns over?
09-26-2017, 01:39 PM | #3 |
Any idea what the heck happened to that old stator?
09-26-2017, 01:51 PM | #4 |
I'm guessing any 50cc 2 stroke coil in the same configuration would work. Most notably a single tab or wire just like your white wire. Does not have to visually look the same. here is an example.
http://www.ebay.com/itm/Ignition-Rac....c100005.m1851 / |
09-26-2017, 08:14 PM | #7 |
The only thing I can think of is someone inserted a screwdriver for leverage to get the nut off....Sad at best.
09-26-2017, 08:15 PM | #8 |
I tried a conventional coil to no avail. I believe because it does not have the CDI
09-26-2017, 08:26 PM | #9 |
Yes a bit but I don't know what the specs are?
09-27-2017, 08:59 AM | #10 | |
09-27-2017, 09:04 AM | #11 |
09-27-2017, 09:05 AM | #12 |
12-27-2017, 08:39 AM | #15 |
there are 2 voltages on these. brain still a bit foggy, but seems like some are 6 volt and some are 12volt units. had a smaller 90cc or so perhaps it was a 120 something and it turned out that the 12v wouldn't work so had to use a 6 volt unit on it. which voltage did it turn out to be?
2007 4x4 300 buyang atv <br />2009 4x4 300 Buyang atv<br />1985 yamaha v-max/2009 fuel inj Yamaha Rhino |
