Old 08-30-2017, 10:56 PM   #1
Jahunt   Jahunt is offline
Vader / Hellcat Exhaust Options
Hey guys, I recently purchased the TaoTao Hellcat 125 , Grom clone. It looks like the Vader exhaust exits the head at a slight rightward angle, rather than straight down like the Grom. Has anyone come up with a bolt on solution for this exhaust port setup?
Thanks!
Old 08-31-2017, 09:51 AM   #2
maldoj2   maldoj2 is offline
the only option is a 50cc exh. and it runsnext to your leg. you can be burn
the exh form a grom will work with a litter modification, you will have to heat it up and twist the pipe. this is my bike ( vader )
Old 09-01-2017, 08:48 PM   #3
zortor   zortor is offline
You got a hellcat? Nice. How's it been so far? Where'd you get it? How many miles have you put on it?
Old 09-02-2017, 11:19 PM   #4
I bought it from a local NC wholesaler. I have about $150 miles so far. Tops out around 55 MPH. It is NECESSARY to replace the two motor mount bolts. The stock one cause sever vibration and the rear broke already. Asides from that, good!
Old 09-04-2017, 03:45 PM   #5
What did you use to replace those mounts? Thanks
