Old 07-21-2017, 03:06 PM   #1
ranchhammer   ranchhammer is offline
magician 250 rear brake pedal
i need to find either a 1"-1 1/2" longer rear brake pedal and or something that extends the pedal pad sideways for my magician 250 rear brake pedal I'm finding that the current setup is awkward for my foot and I've been relying on my front brake to much because of the awkwardness i have adjust the brake pedal which only helped a little. just not sure what i need exactly may have to try several different things suggestions would be greatly appreciated
Old 07-21-2017, 04:19 PM   #2
Mudflap   Mudflap is offline
If the brake peddle is made of flat steel bar stock like most Chinese bikes you can remove it, put it in a vise, bend it to the shape you want. A welding shop could add in a piece to lengthen it also.
Old 07-22-2017, 11:55 PM   #3
green_hawk250   green_hawk250 is offline
I straightened it with a big hammer, repainted, and added the pedal cover from here -
https://www.aliexpress.com/item/Moto...11084462.html?
It is much better now.
