Old 07-14-2017, 10:53 PM   #1
jayr   jayr is offline
New ownwer of a China enduro!
Hi, hoping someone could give me some info on this bike i picked up.
It seems to be a 05 hauwin cheetah 200cc ? i cant find any info on this bike. picked it up for $200 with 100 miles on the dash and the plastic still on the seat.
Old 07-15-2017, 12:20 AM   #2
hertz9753's Avatar
http://www.chinariders.net/showthrea...hlight=cheetah
Does it look like that, but in better condition?
Old 07-15-2017, 01:06 AM   #3
humanbeing's Avatar
ftp://safercar.gov/MfrMail/ORG1302.PDF Huawin = related to Loncin
Old 07-15-2017, 06:48 AM   #4
Sounds like you got a heck of a deal on what is essentially a brand new bike. If it sat that long then I would expect some small work here and there ahead of you. Definitely pull the carb and look it over. I would also be prepared to replace most of the rubber lines as well. Change the enigine oil and crank it over without fuel for a little bit to circulate the oil through the motor as well.
Old 07-15-2017, 01:53 PM   #5
I remember the Kazuma Cheetahs from the mid-00's being discussed here, which is what I am guessing you bought. No one really knew much about Chinese bikes back then, but thanks to experience and this site, it seems that these things can go on forever as long as you are willing to turn a wrench.
Old 07-15-2017, 05:55 PM   #6
Ran across this thread last night. its the same exact bike shown in this thread.
http://www.chinariders.net/showthrea...ghlight=huawin
I cleaned the carb out which was pretty dirty. put some fresh gas in the tank changed spark plug & oil. and she fired right up.
but its bogging really bad when i give it some throttle.
does anyone have a service manual for these lifan 200cc motors?
I want to check valve adjustments.
And carb settings.
Old 07-15-2017, 10:45 PM   #7
dpl096   dpl096 is offline
dpl096's Avatar
Welcome aboard and congratulations on your "barn find"
― Thomas Jefferson
Old 07-16-2017, 01:36 AM   #8
Search CG125 valve adjustment; that will answer your questions (it doesn't matter that the displacement is different).
Old 07-16-2017, 05:51 AM   #9
Mudflap   Mudflap is offline
I can't see in the picture is the engine is a CG or CB clone. Pics of that bike on Google appear to show a CB clone engine.
Old 07-16-2017, 04:32 PM   #10
Thanks
Old 07-16-2017, 04:32 PM   #11
OK I'll search that up.
Old 07-16-2017, 09:25 PM   #12
The starter says cb200. Will that indicate it's a cb clone?
Old 07-17-2017, 12:22 PM   #13
In retrospect, I also think it's a CB. If it has caps on the valve cover that can be unscrewed to reveal the valves, it's a CB that has an OHC.
Old 07-18-2017, 11:46 AM   #14
It does have the caps that can be unscrewed.
Old 07-20-2017, 01:13 PM   #15
Where can I find the rear drum brakes for this bike?
