07-10-2017, 03:17 PM | #1 |
Chinese Honda ST clone
Hello everyone
My wife is learning to ride, she is now practicing on a scooter but she doesn't like the sitting position of the scooter, she is on the small side (don't tell her I said that! ), a full size bike is too tall for her to start on and feel confident being her a beginner, so I thought about the Honda ST clone, she likes it, so we will check one this weekend at the local dealer. One thing that worries me is that the one available around here is a 90cc, that's just fine for around town, but not sure about hill climbing, I live up a mountain so that is an issue, it won't be nice for a newbie rider having a mob of angry cagers behind her honking and overtaking dangerously because she is going too slow uphill . The question is, I have seen ST clones on a 125cc configuration, the scooter is 125cc and do just fine doing those same hills, so is it possible to buy a 125cc jug and piston (BBK?) and putting it on the 90cc engine? This is the bike: |
07-10-2017, 03:29 PM | #2 |
I just found those bikes where called ST, DAX and Trail, depending on your geography.
07-10-2017, 03:31 PM | #3 |
That is a ct70 clone not a st90 clone ,st90's are a little larger bike ,and they have spoke wheels and were only available for about 3 years or so ,at least in North America .Anyways ,the bike you are looking at will have a general pit bike engine in it ,yes you can make it a 125 ,bit it will take much more than a jug and piston ,they sell those bikes with bigger engines in them ,or you would be better off swapping an entire larger engine in rather than dealing with the issues making the engine larger .
07-10-2017, 04:02 PM | #4 | |
Do you know what is needed to do the upgrade on the stock engine? I would like to know that before pulling the trigger on the bike. |
07-10-2017, 04:43 PM | #5 |
I wouldn't bother doing it ,but you will need a new crank ,the cases will need to be machined ,chances are the bushings in the cases will need to be replaced with bearings ,the cylinder ,piston ,bigger valves or a new head ,depending on who the actual manufacturer is of the original engine and how cheap it was built ,starter shafts and gears are stronger as well ,it would be fun to do but the reality is it doesn't make financial sense when you can buy a properly built engine complete for less than the price of the parts .I guess a carb,and exhaust would have to be added as well .
07-10-2017, 05:08 PM | #6 | |
07-11-2017, 12:34 AM | #9 |
IIRC, the 90 shares the same stroke as the 110, so you could (theoretically) swap a 110 jug and piston onto the 90, perhaps without needing to hog out the case. it wouldn't gain you much, but 20cc's would help. As Bruce pointed out, you'll need to rejet and you'll likely want a free-flowing exhaust.
07-11-2017, 06:46 AM | #10 |
The actual Honda 90 cc engine is that way Weld ,but the one pictured is a z50-ct70 style pit bike engine ,as far as I know nobody is copying the Honda 90-110-125 (125 m three wheeler )units which is a little different with the ignition on the cam in the head ,and the lower mounting point is in a slightly different place .To get a 50-70 to 90 cc ,is just a jug and piston or a bore job netting 88 cc which is cheap and easy ,after that you start into cranks etc to get larger ,then you have to beef up everything else as you are now stressing the engine well above its usual power .I wouldn't bother building one myself when I can buy a good new one for $20-$40 more than a clone 70 .
07-11-2017, 12:17 PM | #11 |
This is an interesting discussion, Bruce. I also understand that horizontal clone engines are based on the Z50 case, typically topping out at 125 (exceptions are the high-strung Piranhas, etc that are 140, 150 and beyond). The bore and stroke relationships as I understand them are as follows:
- 50 and 70 share a crankshaft but have different bores - 70 and 90 share a bore but have different strokes - 90 and 110 share a crankshaft but have different bores - 110 and 125 share a bore but have different strokes I can't recall where I learned all that, but it was most likely Dr. ATV or Scrappy Dog. If that info is correct, then a 90 could be bored to a 110 with just a cylinder and piston. I have no way of proving or disproving my statements, although I might have a Baja 90 crank laying around.
07-11-2017, 02:38 PM | #12 |
I am not an expert on them other than anything over 88 cc becomes a money pit ,and just not worth it to build one yourself when you can buy one ready to go for less .I originally thought you were talking trail 90 -110 engines ,which are a totally different animal .From what I do remember in pit bike engines ,50-70have a different bore ,installing an 88 cc kit is also a bore ,110 gets into a crank ,and after that I just do not remember at all ,I have found it's not worth doing much internal repair work on anything 110 cc or bigger ,just get another engine ,they are usually highly stresssed and generally not worth getting into .I think dr atv would be where you can easily find out the combos for the different displacements .
07-11-2017, 02:49 PM | #13 |
Typically, a 90cc (really 86cc) Chinese engine will have a 47mm bore and a 49.5mm stroke, and the cylinder is usually 69mm tall. Using a 54mm big bore kit will yield a final output of 114cc (really 113cc) and you shouldn't have to bore the cases, most of the Chinese engines will accept the 54mm spigot. I believe it is a 13mm wrist pin, as well.
Click here to see the TBParts.com kit |
07-11-2017, 04:33 PM | #14 |
The engine model is 1P47FMF according to the dealer, that might help solve the mystery
07-11-2017, 06:57 PM | #15 |
This is more along the lines of the kits I was talking about for a 110 conversion on a crf type engine .I don't know enough of the ins and outs of the clone internals ,but dirtbkr's post shows it might be a doable deal if you are starting from a clone ,I have several blown up clones and originals here in all sizes ,I might pull a few top ends off and try mixing and matching different barrels to see if everything does work as drtbkrs post shows .
