Old 06-29-2017, 12:43 PM   #1
Skin Mechanic   Skin Mechanic is offline
Skin Mechanic's Avatar
Has anyone tried linking the brake system?
The little monster's rear master cylinder is a joke. I pressure bled the system and the braking is still almost non-existent. I have a 16mm front master cylinder sourced from an old Ducati 916 that should be big enough for both the front and rear calipers. The only thing I need is an adjustable proportioning valve and a coupla banjo fittings. I'm thinking a 70/30 front/rear bias would give me better braking without having to worry about fishtailing if I lock the brakes up.
2017 Ice Bear Little Monster, work in progress
2007 Aprilia RSV1000R, unreliable piece of sh*t
2007 Moto Guzzi Breva V1100, epitome of reliability
2000 Moto Guzzi California V11, resting in pieces
The cage: 1998 BMW Z3, 1.9L w/full Dinan engine upgrades
Old 06-29-2017, 04:42 PM   #2
prismways   prismways is offline
prismways's Avatar
Interesting, I haven't actually tested the quality of the rear brake on it's own. Are you saying you're not able to slow down or stop at all?
I've never replaced a whole brake system so interested to see how you would do it.
Old 06-29-2017, 08:03 PM   #3
If I had to panic brake using the rear brake I would probably jump off the bike to avoid impact It should be a straight forward mod; The master cylinder is fitted with 2 brake lines. One brake line goes straight to the front caliper, the other goes into the proportioning valve with a third line connecting it to the rear caliper.
http://www.jegs.com/i/JEGS/555/63022...QaAoUaEALw_wcB
Old 06-30-2017, 06:37 AM   #4
bogieboy's Avatar
Have you tried just replacing the master? I had a run of bad master cylinders on the front brake of my bike, took 3 to get it working right... also be sure to use fresh dot fluid... other fluids can eat the seals right out of them (found that out the hard way with an accidental top off with power steering fluid... dang bottles look too similar...LOL)
Old 06-30-2017, 07:29 AM   #5
Huck369   Huck369 is offline
Huck369's Avatar
By linking the brakes, you run the risk of total brake loss in the event of failure.
I've had a couple Guzzi with linked brakes, but they always had a separate system that worked one of the front rotors.
I'd advise against it.
But, yes, I would try to get the rear brakes working better.....
Huck
2013 Honda NC700X
2013 Moto Guzzi V7 Stone
2016 AJP PR4
2022 Templar X 250
2021 Sondors Metacycle
AMA Life Member
Old 06-30-2017, 10:27 AM   #6
Brake failure isn't an option when your riding style is beyond aggressive I used what was left of a fresh bottle of DOT 4 in the rear master, after installing a shorter SS brake line on the front. Hmmmmmmm, I could try retrofitting the rear master cylinder from my California parts bike and use one of the shorter tie rods from the Cali's shift linkage to attach the brake pedal to the master.
Old 06-30-2017, 03:31 PM   #7
Rangerscott   Rangerscott is offline
Look up the braking diagram of the '98-'01 and '02-'09 honda vfr
