My RPS Magician is a death trap!
This bike looks great, rides good, love the weight.. But it's falling apart after 3,000 miles and is very dangerous. It's never been ridden rough, and I weigh 160lbs. It had potential, but the frame is so brittle it snaps when stressed. I've had one shop refuse to repair it because they didn't want to be liable,. evidently the steel would just continue to break down after repair.
I really wish it would have been more durable. ![]() |
I would head straight to Harbor Freight for a stick or wire welder and use this opportunity to learn a fun new skill. Plenty of YouTube videos.
This is normally on sale for $80.00. https://www.harborfreight.com/90-amp...der-61849.html This is normally on sale for $130.00. https://www.harborfreight.com/80-amp...der-61749.html / |
Darn shame. Its a cool looking bike, to me.
I agree with Adjuster about getting a stick welder and adding some gussets to the parts of the frame that are prone to failure. With some experience, you may be able to fabricate custom exhausts. A lot of riders seem to want to add an upswept exhaust to their street bike these days and call it a scrambler.
"Its not WHAT you ride; its THAT you ride" |
I haven't seen this bike's frame but I can't help but think that you could probably find someone local to weld and reinforce or even fabricate a new frame that wouldn't hurt your wallet too badly.
Can you post more pics of the first break?
Agreed, if you have time and want to learn, perfect opportunity to bend and stitch a new skeleton.
in the first picture the broken part looks like the top down tube plate ??
Since it craked in the first place it could be a high carbon steel.. So not knowing what the steel is... yer just can't grap a welder and attack it like a big dog on heat.... If I was doing the job i would use a arc "stick" welder with a Austenic welding rod or 2nd choice would be a low hydrogen rod.. Austenic rods are one of the easyest rods to use, But to run a low hydrogen rod you REALLY have to know how to arc weld... or you will end with that much slag inclusion in the weld vee the crack .. weld it ..then back cut the weld/crack deep enough to cut into the front weld....then do the back weld.. And DON"T force cool it...... have fun... ..
opportunity to learn a skill, or have someone weld it or not... It's obvious that the Magician frame needs some structural reinforcement in order to take rougher off-road riding on. With it's more limited suspension travel, it is likely the Magician has a stiffer suspension to prevent bottoming, which means the frame of the bike is likely to absorb more strain from harder bumps. The Magician was intended to be a mostly on-road bike that could take on a dirt road or light trail at best.
I hope you can find somebody that will be willing to weld that frame up for you. Definitely consider having bracing or at least some reinforcing done to those areas, even the ones that didn't break yet, if you plan to continue using the bike in harsher conditions.
#10 |
I found that brazing does a better job than welding. I've repaired a few cracks on motorcycle frames and bike frames and never had any issues with it cracking again where as I have had repairs I've made by welding cracked again.
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 06-21-2017 at 11:35 AM. |
#12 |
Brazing is actually a great way to reduce cracks at high stress joints. I've seen entire tube frames welded together with silicon Bronze Tig "brazing" which is somewhat of a cross between a weld and a braze joint.
#13 |
Damn, those frame cracks are scary looking ,I get the Magician is primarily a street service machine for occasional light off road use but no frame ought to split like that, or in multiple places in that short a time frame in my opinion.
I'd definitely contact the Dealer or Manufacturer or some damn body about it , and see if they aren't willing to address the matter ,surely they don't want that out there repping their brand / make /model. |
#14 |
I feel the need to reply to this.. I've been buying/selling/riding Chinese stuff since around 2002. LITERALLY everything I've had has had this issue, and it's usually not the horrible MIG welds and I've seen it just with frame flex on paved road turns..
