Old 05-31-2017, 07:33 PM   #1
goldstryker88   goldstryker88 is offline
goldstryker88's Avatar
Adjustment to safety switch on brake pedal.
Both Rhinos running flawlessly except...sometimes I can't get one of the units to start unless I stand on the brake pedal. Is there an adjustment that makes that switch more/less sensitive? I thought the actuator for this was in the brake lever housing on the handlebars. When I engage the brake lever it won't start...when I apply a normal amount of pressure on the foot pedal it won't start....when I apply a load of presssure on the brake pedal it starts right up.
Old 05-31-2017, 08:53 PM   #2
Mudflap   Mudflap is offline
The Rhino uses a standard motorcycle brake switch that can be adjusted. Only takes a minute. Find it at the back of the brake peddle lever attached with a small spring.
Old 06-03-2017, 03:41 PM   #3
brake light switch
once you have that adjusted so the brake light comes on when depressed... put some silicone on the threads so they do not come out of adjustment again... can not tighten them up as they are plastic...
ABIBABA ATV ETC
Old 06-04-2017, 12:22 PM   #4
Thanks guys!
Thanks for the responses. Stuck out of state till the 15th. When I get home I will apply your suggestions and give you feedback.
