Old 05-31-2017, 06:48 PM   #1
Color of the day   Color of the day is offline
Color of the day's Avatar
Location: 484 miles east from the geographical center of the United States
Front end noise
I was out riding and took a nice S curve about 50mph and was leaning to the right. There was a small bump in the curve and front end made a noticeable clank as i went over it.
I check everything and all is there and tight. Can forks make this noise?
Thanks.
"Tolerance is not the same thing as acceptance, and acceptance is not the same thing as an endorsement"
Life Member VFW / Life Member NRA / WWG1-WGA
Old 05-31-2017, 07:08 PM   #2
Color, did you notice anything other than a sound....like a severe jolt? It is possible that something in the front suspension is loose. Another possibility is that the suspension bottomed out (why I ask if you felt a jolt). You can check out the various parts to see if anything is loose, also put a zip tie on the male slider of one fork so you can see how much suspension travel you are using. It is possible that you need to add some preload. Other than those possibilities I'd say that the last resort is to take the forks apart to look for something loose inside.....not my idea of fun.
Peter Y.
Another thought.....if you have the center stand installed that might have bounced and then slammed back into the frame.
Old 05-31-2017, 10:25 PM   #3
I checked everything on the front. Seems to be tight. I do have a center stand and that may the source. When I finished riding for the day, I noticed that my center stand was preventing my side stand from being deployed.
The bike was great. We had a 14 mph cross wind. That was not too much fun. The more I ride this bike, the more I like it.
Old 06-01-2017, 08:24 AM   #4
Sullybiker's Avatar
I don't have an RX3 but on my Ninja it's not unusual for bumps in the road to cause the occasional clunk, and it's deceptive where it actually originates from. Sometimes it's the front floating caliper clunking (it has a tiny bit of play), occasionally the chain will slap the swing arm at the looser end of its tolerance too.
You could also - if you were on maintenance throttle (in a turn if you're not rolling-on you're actually decelerating slightly) or even lifting - have compressed the forks a little; they may have bottomed.
Old 06-05-2017, 10:17 AM   #5
Color, the side stand must be deployed before you deploy the center stand...and you must store the center stand before doing the same to the side stand. If you do not do this in sequence the center stand will not go all the way back up to the frame, it will foul on the side stand. I bet you are hearing the center stand banging because it is not being held in the up position by the retaining springs.
Peter Y.
Old 06-06-2017, 01:02 AM   #6
I have a strap that hold the centerstand up as it would cluck badly when riding offroad. Drove me crazy...thus the strap.
2017 BMW F800GS Adventure
Old 06-06-2017, 05:14 AM   #7
pete   pete is offline
pete's Avatar
sounds like the forks may have toped out on the return stroke...
wouldn't hurt to check the fork oil...
but a clunk can come from so meany places...
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 06-23-2017, 10:55 AM   #8
Inroads   Inroads is offline
Mine front end clunks too after a good jolt.Youre not alone.
