Old 05-27-2017, 10:51 AM   #1
jfeliciano15   jfeliciano15 is offline
Hawk CDI upgrade question
Has anyone done a CDI upgrade on the Hawk 250 and if so what CDI unit did you get? Also was it plug and play or did you have to do some wiring reconfiguration?
Old 05-27-2017, 10:41 PM   #2
kirbo7106's Avatar
I was looking into that too. Most of the name brand companies are to expensive and I don`t think that they make a model for our Chinese bikes. I did see one for a Chinese moped/scooter and it was fairly cheap. Keep us posted if you find something that works.
Dan-O
-2018 Tao Tao HellCat - DOA
Old 05-28-2017, 01:57 AM   #3
hertz9753's Avatar
Some people have tried but it didn't work out.
Old 05-28-2017, 07:26 AM   #4
BigWeld   BigWeld is offline
BigWeld's Avatar
Yeah, I remember reading that not only is the timing retarded too far in those cheaper units for easy starting, but it's benefits are barely worth the trouble of installing it. Trouble is (I think) that it's not variable. What I mean is, your timing needs to change at different rpm for maximum performance, but these cheap chi units can't physically do it and even if they could, they're not adjustable
Rides a 2016 Bashan 18C with Blue PlastiDip, piped and jetted, USB charger, real-time digital volt meter, faux carbon fiber handguards, 5 COB led headlight upgrade, auxiliary led light bars, and an MSR shift lever with new grips, T6 aluminum handlebars anodized in blue, polished handlebar brace, decals, HD Unibear chain and spoke covers waiting on the always-full mod shelf......
Old 05-28-2017, 10:45 AM   #5
mjstef   mjstef is offline
Not worth it. Mine went in the garbage.................
Old 05-28-2017, 08:31 PM   #6
Thanks for all the feed back and I will let you guys know if I find a way of making this happen. Enjoy the holiday!
Old 05-30-2017, 08:34 AM   #7
kirbo7106's Avatar
Here's a link to the cdi unit that I was looking at:
https://www.vmcchineseparts.com/coll...nce-version-43
I haven't looked to see what plug configuration our Hawks have.
Keep us posted on what you find out.
Dan-O
Old 05-30-2017, 08:55 AM   #8
A programmable CDI will be the best one to get if you can get one. I've been trying to get this one but having a hard time getting any information on availability or cost. http://www.dansgaragetalk.com/topic/...-time-mapping/
Additional Info- I found where to buy the programmable CDI for under $85. https://www.aliexpress.com/item/Digi...e-dc34455d668e
2004 Honda ST 1300
Old 05-30-2017, 10:55 AM   #9
kirbo7106's Avatar
The CDI that JerryHawk250 was looking at is a better unit. The one I was looking at is more like an MSD Ignition box.
Dan-O
Old 05-30-2017, 11:02 AM   #10
The programmable CDI would be the best way to go. I'm holding off on buying this one because I'm planning on doing the EFI system later on after the summer which already is programmable. You basically copy and burn the information from your stock cdi and adjust timing from there.
Edit: will not work. DC CDI. Hawk requires AC CDI
2004 Honda ST 1300
Old 05-30-2017, 12:13 PM   #11
kirbo7106's Avatar
Efi
JerryHawk250...tell us about this EFI you speak of! This isn't one of those EFI systems that cost more than the Hawk itself is it?
Dan-O
Old 05-30-2017, 01:08 PM   #12
joker   joker is offline
Having trouble finding brozz upgrades
Hello all I'm trying to find some info on upgrading my 2016 brozz. the carb, rear drum, a battery (mine won't hold a charge) and also an exhaust with a new header. My bike currently has 560 miles and climbing. No issues so far with the bike, although I've had to adjust the valves about 4 times and the battery not working.
Old 05-30-2017, 01:15 PM   #13
There about $235 + shipping https://www.aliexpress.com/item/micr...ddresstype=600
2004 Honda ST 1300
Old 05-30-2017, 08:27 PM   #14
kirbo7106's Avatar
Hey JerryHawk250,
When you start your EFI conversion, you will have to start a new thread/post...with lots of pictures! You should start the thread/post when you place the order.
Dan-O
Old 05-30-2017, 08:43 PM   #15
If you do the EFI conversion then turbo should be doable.
