Old 05-15-2017, 07:10 AM   #1
PhildoScaggins   PhildoScaggins is offline
Vader - Valve clearance
Does anyone know the valve clearances for the vader 125cc, are they the same as the grom? I'm at about 100 miles so I plan to do a valve check/oil change today. Also do we have a list of bolts to hit with loctite? I know I should probably just replace the motor mount bolts and swing arm bolts, anything else to consider?
Old 05-15-2017, 09:40 AM   #2
Lucas@Air_Lift   Lucas@Air_Lift is offline
For valve clearance, taken from T Bolt USAs website..
"Adjust your tappets to .003" intake and .005" exhaust"
***Convert your engine to Electronic Fuel Injection***
Trail:
07 Coolster: Lifan 1P52FMI, PZ26 carb, red bars, CNC throttle, "Metal Mullisha" plastics (the GF's bike)
16 SSR SR125: PZ26, New Racing CDI, Blue plastics, LED headlight
Street:
16 Boom Vader 125: Microsquirt EFI conversion, HID/LED headlights, 17T front sprocket, O-Ringed Gold chain, adjustable rear damper, The DD
Old 05-15-2017, 02:04 PM   #3
Old 05-15-2017, 05:21 PM   #4
Angry
GRRR! I removed the lower valve cover with ease. The top cover has bolts that are way over torqued. There isn't enough room to get a 6-point ratchet in and I'm too afraid to continue with a standard wrench in fear of stripping. Vice grips have provided no relief either. Has anyone else encountered this problem?
Old 05-17-2017, 01:41 PM   #5
prismways   prismways is offline
prismways's Avatar
Yeah, i was lucky to have a thin walled sockets set that I picked up at Home Depot a while ago.
Old 05-20-2017, 07:28 AM   #6
I'm about to finish my soft break-in of 500mi. My plan after is to do the carb swap. Hopefully when I get the air box off I can get at them with a impact gun.
