05-10-2017, 04:51 PM | #1 |
Motor mount bolts replaced... Don't fear the Reaper
The bike has had some vibration when decelerating thru 6k-5k rpm range. It got progressively worse on the 128 mile ride today. I started checking the bike out after it had cooled down. The only thing loose was the chain, like "I'm surprised it didn't fly off the sprocket" loose. The swing arm bolts were tight, so I decided to pull the front sprocket cover and found the problem. The head sheared off the lower motor mount bolt. Story of my life
2017 Ice Bear Little Monster, work in progress 2007 Aprilia RSV1000R, unreliable piece of sh*t 2007 Moto Guzzi Breva V1100, epitome of reliability 2000 Moto Guzzi California V11, resting in pieces The cage: 1998 BMW Z3, 1.9L w/full Dinan engine upgrades Last edited by Skin Mechanic; 05-15-2017 at 04:18 PM. Reason: status update |
05-10-2017, 05:06 PM | #2 |
Wow! Im'a pull the cover off mine and check this tonight! are you able to find a replacement? does the motor "rock" at all if you push pull on it in the frame?
best of luck! |
05-10-2017, 07:14 PM | #3 |
I ordered some replacement bolts from McMaster-Carr. The engine is hanging loose at the top motor mount. I'm gonna replace both bolts and use fender washers at both ends.
2017 Ice Bear Little Monster, work in progress 2007 Aprilia RSV1000R, unreliable piece of sh*t 2007 Moto Guzzi Breva V1100, epitome of reliability 2000 Moto Guzzi California V11, resting in pieces The cage: 1998 BMW Z3, 1.9L w/full Dinan engine upgrades |
05-10-2017, 11:49 PM | #4 |
Holy crap. Good thing you weren't injured. I will consider changing mine out too!
What was the size and type of bolts did you order? |
05-11-2017, 08:42 AM | #5 |
for the bolts on the Vader it is 4 1/2" by 5/16 for the bottom and 5 1/2" for the top engine mount bolt.
05-11-2017, 11:36 AM | #6 | |
I've been doing a little reading on bolt failure and this is common when a bolt has to hold a part in place as well as setting it's location. If shims were used to align the motor and mounting bracket, this probably wouldn't have happened. Isolating engine vibrations with bushings in the mounting brackets would probably have prevented the break as well.
05-11-2017, 12:01 PM | #7 |
The old timers on normal bikes have also warned about out of box loose mount bolts too.
05-11-2017, 04:21 PM | #8 | |
05-11-2017, 05:10 PM | #9 |
Looks like it was WAY over-tightened at the factory. These motor mounts on most CB's only take about 18-22 ft lbs, depending on bolt thickness. Having them all torqued evenly is far more important than "bear down tight".
Better check the rest. On Mrs. 2LZ TT250, it had a bad vibration and I found the motor mounts in all different torques. I evened them up and the vibe went away.
05-11-2017, 11:46 PM | #10 | |
05-12-2017, 02:33 AM | #11 |
purchasing anything because it was 1/3 the cost of an original is also the reason bolts break like this .Instead of real butter ,they use the I can't believe it's not butter bolts to sell at the price point that gets them out the door .
05-13-2017, 05:22 PM | #12 |
I've bought a lotta crap from China, with emphasis on "crap". It's to be expected. I wasn't surprised that the naugabutter bolts were pitted with rust, like the original gas tank. I guess their parts department is on a flood plain. There's also too much side play in the mounts. I'm not gonna bother buying real shims, I've got a coupla PBR cans that will work just as well.
05-13-2017, 05:33 PM | #13 | |
not sure what all these acrononyms and jargon is about, but interested to see how you secure the motor and mounts.
05-13-2017, 09:56 PM | #14 |
Lol real pbr can shims on a China bike.....here hold mah beer!!!! I do love the way we all jerry rig our CBS to make them work
05-13-2017, 10:55 PM | #15 |
Well damn! At least you weren't hurt. I'll have to keep an eye on mine.
2002 Harley Davidson XL883R 2012 Yamaha FZ6 2022 Hawk 250 2002 Yamaha R6 *sold* Vader 125cc *sold after owning for many years* 1997 Jeep Wrangler *sold due to frame rot* |
