Old 05-01-2017, 06:58 PM   #1
Goody302   Goody302 is offline
Goody302's Avatar
Vader with 26mm mikuni...
Ok, so rode for a little bit, seems at WOT in higher RPMs, 5500-7000, it seems hesitant. Fine rolling into throttle, but as RPMs climb, seems to flutter. Now, granted only have 5 miles on this machine so far...lol. I got home, plug looks to be rich, wondering if I'm too rich since still stock exhaust. Only changes is mikuni 26mm carb, air filter on end of it. Running a 115 jet. No idea what stock jet is as my stock carb has flat screws to it...no idea how to get it apart. Screws on it look like just like a solid circle, nothing ya can put on em. Thinking of trying a 105 jet since I bought a jet kit with carb.
Any ideas folks?
Any help appreciated.
Thanks.
Old 05-02-2017, 06:05 AM   #2
Skin Mechanic   Skin Mechanic is offline
Skin Mechanic's Avatar
105 sounds about right. Getting the float bowl off the stock carb is easy. Use a cut off wheel on a Dremel to cut a slot in the screw heads and remove them with a flat head screwdriver.
2017 Ice Bear Little Monster, work in progress
2007 Aprilia RSV1000R, unreliable piece of sh*t
2007 Moto Guzzi Breva V1100, epitome of reliability
2000 Moto Guzzi California V11, resting in pieces
The cage: 1998 BMW Z3, 1.9L w/full Dinan engine upgrades
Old 05-04-2017, 09:25 PM   #3
Jrack   Jrack is offline
Dremel worked for my stock carb. Put a 90 jet in and it's doing the same thing. I ordered a vm22 mikuni carb and I hope that makes a difference. Not sure how it's going to work with the stock exhaust. If anything I'll gut the cat and see how it runs after that or just order a new exhaust but I'm not sure which one yet.
