04-23-2017, 08:25 AM | #1 |
Trouble Shooting Before Actually Shooting
I have just finished assembling a BMS 500cc Ranch Pony UTV. The dealer doesn't supply you with an assembly manual, just an online and rather incomplete video. Got things figured out and only missing a couple of screws and a grommet.
BUT, I am having trouble getting it to start. I had to use ether to start it the first time and it ran just fine. I rode it for a while, put it away and the next day, it wouldn't start again. Is there some adjustment I'm missing? For that matter, is there a downloadable assembly manual, in English, for these things? |
04-23-2017, 05:02 PM | #2 |
manual
Hello.... everyone thinks there should be a manual for this stuff.... there are video.s to assemble them on YOUTUBE... LOOK AT IT.. wheels on charge battery.. there is a fuse if it would start... etc... common stuff.... you need a repair manual... buy a HONDA ATV REPAIR MANUAL.... USE SOME COMMON SENSE. this is what people do not have,.. if you got a problem you can not figure out... post it here... keep your bolts tight .. air in th e tiores,.. adjust your chain.... the big thing... use the real gas.. change your oil .. and think..
04-23-2017, 07:37 PM | #3 | |
04-24-2017, 11:55 AM | #4 |
for your starting issues, are you using the choke? not sure where it is on your machine, some have a handlebar mounted choke cable, others have the choke right on the left side of the carburetor...
04-24-2017, 01:42 PM | #5 |
I would think a model like that would have a choke on the dash... the cable might need to be adjusted to be fully closed.
04-25-2017, 04:44 PM | #6 | |
Even if it were eventually tested in a court of law, I think the judge would consider it only reasonable that a machine that you have to assemble and that can kill you should come with assembly instructions. If the dealers of Chinese UTV kits, which is really what they are, kits, can't pony up a copy of the assembly instructions specifically for the machine they sell, they may eventually find themselves liable if someone gets hurt even with the disclaimers they put in the contract. This is the kind of stuff consumer protection agencies love to get their hands on. Thank you anyway for referring me to a Honda service manual. It might be helpful. |
04-25-2017, 05:25 PM | #7 |
Looks like you didn't need a assembly manual. The service manual will be helpful and so will this site if you respond to the questions asked.
1986 TT350, 2002 Grizzly 660, 2009 TR125 and two 2015 Kandi 150cc Quads. |
04-25-2017, 05:25 PM | #8 |
I'm not sure about the motor but I think the body, etc....is a copy of the Yamaha Rhino, if you can find info on that, as well.
I've been nosing at one of these at Tractor Supply. I think your BMS is the same as the Massimo 500, if you can find something on that.
04-25-2017, 06:26 PM | #9 | |
our county deputies are just waiting to catch a quad on the road
04-25-2017, 06:51 PM | #10 | |
04-25-2017, 08:00 PM | #11 |
Haha, ha ,ha,ah . We're with the government, we are here to help
04-26-2017, 10:09 AM | #12 | |
What's this "tax refund" you speak of? Are those words a foreign language? I don't recognize them..... Our TSC has them for 6999. The lowest price I've seen recently on the Box Store sites for the BMS equivalent (CARB Approved) is 5999 and that doesn't include shipping. Probably why Snerdguy isn't too happy at the moment. They aren't cheap.
04-30-2017, 11:35 AM | #13 |
You May Not Believe This
Well, it seems to be fixed. But, the fix was accidental. It wouldn't start without ether and it idled to fast causing shifting problems. The problem it seems was in the throttle adjustment screw itself. While looking for the problem, we tried adjusting the throttle limiting screw on the extension cable to reduce the idle speed and nothing seemed to happen. So, we flexed the line and what do you know, the built up torsion in that line released and the idle dropped down to where it was supposed to be.
All of the problems with getting the new BMS Ranch Pony 500cc working properly were caused by that badly engineer adjustment cable. Judging from other owner's complaints, this may not be an isolated incident. People need to check that the cable or spring in that short extension isn't binding when they turn the screw. Hopefully we won't have any other problems for a while. Thanks for your help. |
05-01-2017, 01:26 PM | #14 | |
Tags |
utv, won't start. |
