Old 04-20-2017, 09:44 PM   #1
Rakkatier   Rakkatier is offline
Stretching China bike
Anyone have success stretching one of the grom clones? If so what kit did you use?
Old 04-20-2017, 10:20 PM   #2
ben2go   ben2go is offline
Assuming you're referring to stretched swing arms, there is nothing. You're own your own. These are cheap Chinese bikes with little aftermarket support.
Old 04-20-2017, 10:27 PM   #3
Completely understand that, I'm questioning whether adapting a kit for an actual grom will work or somewhat work, if dimensions are completely off or it's doable with motivation and the right tools
Old 04-21-2017, 03:44 AM   #4
pete   pete is offline
pete's Avatar
I added 75mm 3" into the frame of my boys pit bike..
cut the frame under the tank and added it there..
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 04-22-2017, 11:15 PM   #5
I'm sure enough money can be thrown at it and something fabricated. I know nothing from the grom aftermarket that would bolt right up. There were some aftermarket extended swing arms for the Grom. Still not a cheap option.
Old 04-28-2017, 12:31 AM   #6
Jrack   Jrack is offline
Depends on the bike. Grom parts fit the SSR Razkull. Not sure about the Vader. I did get a fender eliminator kit to work. Had to drill out the holes on the bike, they were close tho. I've been thinking about stretching my Vader as well. Not sure if I want to be the first to tackle that project. I'll probably wait to see what someone else does first and go from there. Also, you can check out brokerichguy on youtube, he has a Razkull lowered, stretched, and with a new exhaust all of which were for the grom. If I were you, I'd ask him about a stretch kit.
Old 06-26-2017, 11:46 AM   #7
maldoj2   maldoj2 is offline
it can be done, it"s easy
Old 06-26-2017, 08:43 PM   #8
Well then. Can you post more info for others to benefit from?
Old 06-27-2017, 01:58 PM   #9
the swing arm fit s with a litter modification, there is a litter over lap inside the arm, the way it was constrcted you have to modify the extencion where the over lap is and the corners too. it is the four cornner i did my with a hand dremel
i made a drawing to show what i did
