04-16-2017, 07:17 AM | #1 |
Gio/Apollo Parts - Oil Drain Plug
When putting my oil drain plug back on my Gio 250 I cracked it :-(
It does not leak, but I don't want to push it and ensure I have a replacement sooner than later. What do you guys do for parts? Is it true these bikes at Honda CB clones? Do those parts fit? I don't really want to pay more for shipping than the part likely costs. Thanks, Ross |
04-16-2017, 08:31 AM | #2 |
It helps to know the size and pitch of the bolt. Check out an auto supply store. They have drain plugs for cars that are a match sometimes.
04-16-2017, 09:06 AM | #3 |
http://bv000245.ferozo.com/despieces...ish%5B1%5D.pdf tells something
36mm (using 24mm wrench) https://item.taobao.com/item.htm?id=525492303489 which same as good old Honda === Typical drain bolt in vertical chonda is 12mm (using 17mm wrench) , there's 14mm variety that common in Suzuki...
04-16-2017, 02:55 PM | #4 |
Thanks!
