Well I lowered my engine and adjusted my valves to .05mm in and .08mm out. The intake was too tight and the exhaust was too loose. I also installed a oil cooler. Now my bike wont idle. The idle varies 500 or so rpm and is way low and the bike will stall if I don't keep on the throttle. Its always been rock solid before. Would the valves being out of adjustment do this? In the past when I've seen this it was a vacuum leak. I had the T on the flywheel lined up and both rocker arms had play.
Bashan Blaze Mods: Alloy Rim's, Muffler, Mukuni VM26 Carb, Foam Filter, Tachometer, Volt Meter,LED Headlight, LED Blinkers Last edited by Merlin; 04-10-2017 at 04:54 PM. |
#2 | |
I forget will both valves be closed at TDC exhaust stroke and I seem to remember something about an uneven idle with the valves too tight?
Bashan Blaze Mods: Alloy Rim's, Muffler, Mukuni VM26 Carb, Foam Filter, Tachometer, Volt Meter,LED Headlight, LED Blinkers Last edited by Merlin; 04-10-2017 at 11:08 AM. |
They should be closed.
I missed the part about exhaust stoke, sorry.
I rotate the engine until I see intake valve move. Then I start looking for the TDC mark.
Zakkly.
Ok now Iam more confused (easily done) should both valves be closed at TDC on the exhaust stroke?
#10 |
Both valves should be closed on the compression stroke at top dead center. TDC on the exhaust stroke should have the exhaust valve somewhat open, and the intake valve opening.
#11 |
Thanks for the info.
#12 |
All of this TDC stuff is too confusing for me
I just turn the crank until one valve is fully open Then you know that the other one has to be fully closed |
#13 |
That's the other way to do it. But for people who have never done this before, TDC on the compression stroke is less intimidating....ARH
#14 |
Still sounds like a vacuum like to me so before I disassemble my bike again Ill check for leaks. My mind says vacuum leak but my intuition says valves.
#15 | |
Did you remove the carb? Do you have the smog stuff still on that would be the only place that any vacuum would be produced.
2016 Brozz |
