Old 04-01-2017, 01:24 PM   #1
BigWeld   BigWeld is offline
BigWeld's Avatar
How much "extra" power do our stators produce?
I'd like to add some lighting, but I have NO idea how much power in wattage can be added to my Brozz's electrical system before the bike's charging system can't keep up.......can anyone educate me on this?
Thanks in advance.
Rides a 2016 Bashan 18C with Blue PlastiDip, piped and jetted, USB charger, real-time digital volt meter, faux carbon fiber handguards, 5 COB led headlight upgrade, auxiliary led light bars, and an MSR shift lever with new grips, T6 aluminum handlebars anodized in blue, polished handlebar brace, decals, HD Unibear chain and spoke covers waiting on the always-full mod shelf......
Old 04-01-2017, 03:27 PM   #2
Merlin   Merlin is offline
Thanks in advance.
From what I've read it's 90 watts.
Bashan Blaze
Old 04-01-2017, 04:19 PM   #3
BigWeld's Avatar
90 watts extra? Where did you find this info?
Old 04-01-2017, 05:38 PM   #4
probably meant it puts out 90 watts
2016 hawk
kaw h1 400 tripple
13' long chopper in progress
2009 johnny pag bar hog
Old 04-01-2017, 05:53 PM   #5
Ariel Red Hunter's Avatar
Thanks in advance.
If you use LED lights, you've got more than enough power.
Old 04-01-2017, 06:02 PM   #6
BigWeld's Avatar
Well, I have the digital voltage indicator with 2 USB ports, plus two 18W led auxiliary lights....hoping I got enough in the system to run the lights when needed at night and still have a healthy charging system
Old 04-01-2017, 10:16 PM   #7
ben2go   ben2go is offline
As long as the charging system can hold 13.7 volts, with everything switched on, you should be ok. If the voltage gets down to 13.5, switch something off and allow the battery to recover. This worked well for me on my GS500.
