Old 03-17-2017, 02:02 PM   #1
ElectricCircus   ElectricCircus is offline
ElectricCircus's Avatar
Mad Rear brake broken hose
Hi.
Just found this on my bike (3500mi), after a sudden loose of braking power at the rear wheel:
So, it´s time to go for a replacement hose.
Any suggestion to avoid this issue with the new hose?
Regards,
Juan Carlos.
______________
- ex Honda MB100 (1981)
- ex Honda Nighthawk 250 (1991)
- ex Honda Storm 125 (2009)
- ex Corven Triax 250 Touring (2016) (Zongshen RX3 carb)
Benelli TRK 502 (2018)
Old 03-17-2017, 02:07 PM   #2
jct842   jct842 is offline
No sharp turns or flexing.
Old 03-17-2017, 02:24 PM   #3
Azhule   Azhule is offline
I would upgrade to some kind of Steel Braided Brake Hose that is a few cm shorter to help take a few of those extra bends out of the original brake line routing
Maybe something like these will be a inexpensive replacement ?
http://www.banggood.com/0_5m-2_3m-Mo...p-1039252.html
or
http://www.banggood.com/60cm-200cm-Motorcycle-Brake-Clutch-Oil-Hose-Braided-Line-Pipe-p-1092407.html
Check the length and banjo bolt hole size to make sure the new lines will work
Old 03-17-2017, 02:50 PM   #4
20.00 bucks at CSC. The shipping would probably kill ya though.
https://www.cscmotorcycles.com/hose-...-p/z49-103.htm
Old 03-18-2017, 08:13 PM   #5
Rear brake hose replacement
Hi guys.
Thanks for the information provided
Yesterday made a quick tour over the local motorcycle part stores: first one offered an original hose at USD35 w/10 days wait; second one another original hose at USD60 w/7 days wait; third one had none; fourth store: there found a generic hose 42" long (mine was 40") at USD22, OEM for Bajaj NS200 Rouser bike.
So re-routed the hose path in order to bring space for the 2 inches extra: perhaps there is an excessive bending at the pump end,, I´ll see how it performs in time.
Also found a curious thing: the RX3 OEM hose has a very stiff internal white plastic pipe (covered with a metallic braid and a thin external plastic jacket), instead of the rubber hose -more flexible- usually found at the hydraulic systems.
______________
Old 03-18-2017, 08:13 PM   #6
Jay In Milpitas's Avatar
Juan Carlos, your hose looks to go much different than ours does. Is this another difference in the Corven Triax 250?
http://www.cscmotorcycles.com/v/vspf...age_%20(1).jpg
As jct842 said, run the hose as loose and straight as you can. Change the position of the front clamp? Leave the front clamp off?
Edit: You posted just before I did. That looks much better. The white hose is usually a high grade plastic (HDPE or Teflon) and the steel braid is there to keep it from expanding under pressure. It is very much like the 6000 psi/41000 kPa hoses that I work with on heavy equipment.
