Old 03-15-2017, 12:16 AM   #1
mjstef   mjstef is offline
Hawk CG engine bore and stroke????
Working with a supplier for the oil coolers and may have found a big bore kit. No promises but MAYBE! What is the stock bore and stroke??
Old 03-15-2017, 12:46 AM   #2
old kid   old kid is offline
old kid's Avatar
this is all the info that is in the owners manual
Old 03-15-2017, 12:50 AM   #3
ughmas   ughmas is offline
ughmas's Avatar
not sure if they are exactly the same or if it makes a difference but the TT250 service manual lists
Bore x Stroke 66.5mm x 66.2mm
2005 CBR600RR
2016 CSC TT250 Coming Soon
Old 03-15-2017, 12:54 AM   #4
I have found a cylinder with a 70mm bore. Still confirming with manufacturer if it fits the CG engine. Been on Whatsapp all night with different suppliers......
Old 03-15-2017, 01:13 AM   #5
hertz9753's Avatar
The CSC uses a square bore engine and is counter balanced. It claims about 16 HP and the Hawk engine doesn't have that and is about 14 HP. Both are good engines but different.
Old 03-15-2017, 03:29 AM   #6
pete   pete is offline
pete's Avatar
67x65= 229cc
70x65= 250cc
21cc or 11% more.
could be good for another 1.5/2hp
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 03-15-2017, 09:12 AM   #7
Ariel Red Hunter's Avatar
67mm bore by 65mm stroke. A 70mm bore on that same stroke is close to 250cc. A 10% improvement in displacement. Should give a 10% improvement in torque. And at least that much of an improvement in HP. The question is if the cases and the case bolt pattern will cover a 70mm bore....ARH
Old 04-04-2017, 06:35 AM   #8
Dilioc95s   Dilioc95s is offline
I am not quite sure about it. return man 3
Old 04-04-2017, 05:15 PM   #9
What are you not quite sure about?...ARH
Old 04-04-2017, 05:34 PM   #10
I recall there being a 177FMM??? (77 being the bore). I'm not sure if it was water cooled or not.
W&G or culcune or some other CR old-timer will know better than I, if they chime in.
Old 04-05-2017, 11:03 AM   #11
I only ever saw large-bore engines like that on Taobao. It's tempting, but I'm not going to order one.
