Old 03-13-2017, 09:43 PM   #1
Mcomfort   Mcomfort is offline
Magician 250 enduro won't star
I just put together my new magician 250 and it will not start. I have the fuel valve on and choke set. Cranks but won't start. Anyone have the same issue?
Old 03-13-2017, 09:48 PM   #2
Ascot500   Ascot500 is offline
The red kill switch has to be set to the right
And the first start will take a lot more cranking than you would think
Old 03-13-2017, 09:54 PM   #3
chuck   chuck is offline
Take your time it's always something small,she will crank up eventually.She has the Hawk in her blood.
Old 03-13-2017, 10:12 PM   #4
Originally Posted by jeffrey View Post
Ascot500... Single or twin.
I bought a '84 twin in '08--owned it until '09 when I stupidly sold it!
Old 03-13-2017, 10:16 PM   #5
I have the kill switch to the right as well. I am charging the battery and will try agin. Thank you.
Old 03-13-2017, 11:14 PM   #6
Ski_rush   Ski_rush is offline
Did you try turning the throttle a little while cranking it? Are you using the stock spark plug?
FYI, mine took longer than I expected to start for the first time too.
Old 03-13-2017, 11:26 PM   #7
Azhule   Azhule is offline
Did you set the valves yet?
Old 03-14-2017, 09:02 AM   #8
I had the single, an 82
Foolishly sold it during a time of weakness
Old 03-14-2017, 10:30 AM   #9
Bruce's   Bruce's is offline
Have you checked for spark ?
Old 03-14-2017, 12:02 PM   #10
If you have spark and the valves are correctly adjusted, try a different position for the choke - mine will start on the mid position but not on full choke
Old 03-14-2017, 12:10 PM   #11
What is the oil level in the crankcase?
Old 03-14-2017, 12:13 PM   #12
Oil level,fuel,spark,crank,ignition..
Old 03-15-2017, 01:51 AM   #13
Bill1   Bill1 is offline
I killed the battery on my Hawk the first day trying to start it. Adjusted the valves and it fired right up.
2016 RPS Hawk 250, exhaust, Uni Filter, Mikuni VM-26 clone w/ 120 main & 30 pilot, MSR shifter, 17/45 sprockets, JT chain, digital cluster...
Old 06-19-2017, 04:39 AM   #14
mattshady   mattshady is offline
I have same problem. Im almost through the entire harness and everything checks out good but no spark.
Old 06-19-2017, 07:16 AM   #15
clark   clark is offline
clark's Avatar
Make sure that kickstand is up. Kickstand has as a kill switch attached; when the kickstand is down, the ignition circuit is open.
Magician 250 (9/2016 engine label)
Kawasaki 650 KLR
Honda 1300 VTX
Qlink XF200
