Old 03-08-2017, 06:42 PM   #1
Rail32   Rail32 is offline
Rail32's Avatar
Modded hawk foot pegs
I have done this on a few bikes and it works well. These are stock pegs minus rubber inserts . Than I take tree climbing spikes as they are knurled and good quality steel for $2.50 each . It takes 2 per side . The cool part is they are tilted up on the end which gives me side support when cornering .
Living life to the fullest to avoid regrets later ,,,,or I am a complete loon ! Either way I am good
Old 03-08-2017, 06:46 PM   #2
Rail32's Avatar
Got this idea from my ATV days and DG pro pegs for like a zillion dollars .
Rail version 1.5 hours and $6
Old 03-08-2017, 07:23 PM   #3
Sir kayakalot   Sir kayakalot is offline
Sir kayakalot's Avatar
I too did a footpeg mod on my Hawk. Can't stand those stock foot pegs! I just took some 1" stock and bent it the shape that I wanted and made it jagged all the way around with a grinder for a good grip then welded them to the stock pegs. Huge difference!! However you choose to do it, just do it. Yours look great.
Hawk 250 Mikuni carb 115 main. De-catted pipe. Air box mod. 15/42 sprockets. Digital instrument cluster, FMF end cap on muffler, handlebar toolbag, Custom foot pegs
Old 03-08-2017, 07:46 PM   #4
1cylinderwonder   1cylinderwonder is offline
Doh! $500.00 foot pegs
Originally Posted by Rail32 View Post
I have done this on a few bikes and it works well. These are stock pegs minus rubber inserts . Than I take tree climbing spikes as they are knurled and good quality steel for $250 each . It takes 2 per side . The cool part is they are tilted up on the end which gives me side support when cornering .
$500.00 X 2 for a pair of Footpegs seems overkill
About the selling price of the Hawk!
Old 03-08-2017, 07:47 PM   #5
Rail32's Avatar
Being a former mechinc , machinist , fabricator and perfectionist has a few good qualities. Thanks
My set on KLR has hit a stump doing about 30 mph and withstood the impact . Me on the other hand was hurting for a week,
Old 03-08-2017, 07:51 PM   #6
Rail32's Avatar
Let me know when you find a hawk for $500 , I want a spare
Spell checkers police have a field day with my posts
I never proof read and I am the fastest 3 finger typer this side of the Mississippi.
It's hard to belive I am a moderator on another forum
Old 03-08-2017, 08:43 PM   #7
Rail..it's all good
Old 03-09-2017, 05:57 AM   #8
I got a cheap set of pegs off of Amazon. I had to modify the return spring on the Hawk to fit, and they tip forward ever so slightly, but they're really great when you get out and tear up the trials. I'll post a pick when I'm down in the shop again. I have to dig out from about a gazillion work emails and then go cut the grass. Here's a picture of the pegs from Amazon.
http://www.chinariders.net/attachmen...1&d=1489057022
First Rule of Aviation:
The Stable:
2005 Yamaha V-Star 650 - SOLD
2015 Suzuki DR 650
2015 RPS Hawk 250 - SOLD
2016 Ural Gear Up
Old 03-09-2017, 07:45 PM   #9
Rail32's Avatar
I bought that exact same set for 2010 KLR and they were ok , at best . The ones I made are 1.5 inches longer . Test rode mine today , no worries about feet slipping off .
Old 03-09-2017, 10:00 PM   #10
That's exactly why I built my own. I wanted LONGER pegs, not just wider. Makes a huge difference, especially when you're wearing boots.
Old 05-22-2023, 05:19 PM   #11
sshoress   sshoress is offline
sshoress's Avatar
Exclamation In search of Hawk OEM pegs with rubber
Hey guys, anybody here wanting to sell me their stock hawk foot pegs with rubber tops? Message me directly !
2023TEMPLAR X 6Sp <3 Central FL
  • Renthal oversized 1 1/8" FatBars, StickyGrips, Nibbi Throttle, Nibbi 30mm Carburetor, Nibbi Ignition, NGK Plug, RX Xring Chain, Upgraded sprockets for top end, 788 PowerCore2 Pro Tork Full Exhaust System, Shinko 7058s, Co1/Senge Graphics Kit, collapsable shifter, steel brake lines, EnjoyMFG Seat Cover, MSD spark wires, Dunlop barkbusters, aftermarket CDi, rear lights rewired under rear fender (clean now)
