as chuck suggested the 115 main jet should be ok with the aftermarket exhaust just make sure you are getting enough air into the carb, i am about an hour north of where you are i cut my air box open installed a K&N filter cut out the cat converter cut the spark arrester i have the mikuni carb with a 110 main jet 22.5 pilot jet the air mix screw is one turn out and the needle clip is in the middle slot. i can start the bike from a cold start on half choke and once it warms up it will run perfectly through all gears at all ranges of the motor.
125/30 is pretty fat for the hawk. I think the higher in elevation the less fuel you need.
I have a 110/20 combo. I'm a little lean down low so I made up for it with needle and screw. I will fix that when it warms up with a 22.5 or a 25. (I forget what the stock pilot is, I think 20?? the main in mine was 98) |
#5 | |
Stock pilot is 20 on the Mikuni clones. Where are you getting yours? I wanted to put a 30 in but I can't find ones that fit.
2002 BMW R1100S, 1999 Kaw Concours, 1991 Kaw Eliminator 250, 1969 Honda Trail 90 Too many damn mopeds... ![]() ![]() ![]() ![]() |
#7 | |
try the CR/YZ pilots thats what fit in mine, i have used mikuni carbs for many years in different things so i had a few jets on hand, but these ones that we are dealing with now are clones so they may not set up the same as a legit Mikuni would be. i settled with a 22.5 for the pilot, i would have to believe that you could find them on E-Bay or Amazon fairly cheep. |
nichecycle.com
I've purchased dozens of main jets and slow jets for 30mm Mikuni carbs (so-called clones) on eBay over the years. I also have a pin vise and a 61-80 drill bit set for custom-drilling of slow jets. That complements my regular numbered drill bit set that only goes as small as 60.
#10 | |
The good news is that Mikuni OEM jets do fit the clones, you can get them from jets'r'us; 'OEM equivalent' works fine. Mains: http://jetsrus.com/a_jets_by_carbure...arge_round.htm Pilots: http://jetsrus.com/a_jets_by_carbure...-486_pilot.htm I'm running 27.5/110 at the moment on a stock bike, though I think a 25 would be absolutely fine. @2lz is to thank for digging these out. |
