Hawk 250 forks
Way too mushy for my weight of 195 lbs and riding style . Tearing down today and swapping to 10 weight real fork oil . Than exploring shim possiblity . Would like to swap springs , but I have no clue where to start . I will measure length and spring material dia . All I know is 31 mm forks at this point . Any direction advice is appreacated highly . What I did find is list of bikes that had 31mm forks I will share here in a few seconds .
I just changed mine to mobile 1 atf. I put 210cc and made a big difference. I weigh about 185
#3 | |
#4 | |
#5 | |
Drained out 6oz's from each fork . Pretty grey color for 63miles , but that's normal here in Wi from what I have seen over the years . Added 6oz's of bel ray 10wt . And added 2 nickels as shims . I have den the PVC pipe shims before and metal in my mind is a better option . Took the hawk around the yard grabbed a little air over ditch and she is much nicer . Before I add anymore I want to measure stroke of travel and calculate spring compression to the best if my ability. I have bent forks in the past from over shimming them . These are the smallest springs I ever seen . Fork tubes are beefy enough , but finding replacement springs is gonna be a challenge . If I need them that is . For some reason I can only load 1pix at a time , bare with me
Nice round 2 foot length . But tightly wound small dia .
I measure and check everything , curse of being a machinist for years .
2 nickels is .120 shim and seems way better already .
#10 |
Progressive Springs probably have springs for those forks. Progressive usually winds springs with (surprise!) progressive rate springs. Usually softer in the middle and stiffer at the ends.
#11 | |
![]() I will try Progessive next .
#12 |
Too much snow here to prove anything out . But after a few sliding hot laps in snow with soft lawn underneath , I believe I made a difference . How much is to be determined later .
#13 |
My other China Girl . Ok not really Chinese, but she's Asain . She is our Japanese Akita Inu
BTW she hates the hawk and chases it all over the yard when I am outside .
#14 | |
#15 | |
Back in my younger cobbling days I have bought hardware store springs and stacked them up to get what I wanted . Sounds crazy , but with enough pateints of trail and error it works . Next step is measuring rear shock eye to eye . That should be an easy find for replacement . BTW I never leave anything alone . It's just my nature
