Old 02-21-2017, 06:36 PM   #1
joeboyk   joeboyk is offline
joeboyk's Avatar
digital cluster problem
hey guys i know a lot of us have received our new clusters and I hooked mine up with no luck,the wires that connect to the back of the cluster must be loose.When i push on the back of them the cluster comes on,but no back light.Anyone else have or had this problem?
Old 02-21-2017, 09:25 PM   #2
rav007   rav007 is offline
just hooked mine up the other day, its the connector into the back. peel back the boot and you'll see the connector. unplug it and re-seat it correctly all the way down. your troubles should be solved at that point. on another note, mine isn't sitting straight :/. BUT it is very VERY VERY nice to have a tach and a speedo that works and a nice display of the gear selector.
Old 02-22-2017, 05:55 AM   #3
chuck   chuck is offline
Use some washers and a longer left hand side screw to straighten the cluster up.
Old 02-22-2017, 06:19 AM   #4
That's what I did.
2004 Honda ST 1300
Old 02-22-2017, 04:07 PM   #5
joeboyk's Avatar
thanks for the help guys headed to the garage now to try it.
Old 02-22-2017, 07:50 PM   #6
joeboyk's Avatar
Update problem fixed thanks for the help.
Old 02-22-2017, 10:46 PM   #7
mjstef   mjstef is offline
I've e-mailed the factory and gave them the heads up. Sorry for your troubles folks. As far as the mounting, a couple washes does the trick. Adding another bracket would take the price up more and it's a simple fix that only about 1/2 of them need anyways.....
Old 02-22-2017, 11:38 PM   #8
Musictrek   Musictrek is offline
Musictrek's Avatar
Hawk Cluster
I added a few washers to level it out. my bolts were way long enough.
Old 02-22-2017, 11:59 PM   #9
Looking good!
