Mikuni Carburetor Jetting INFO
I put the Mikuni Carb on my 250 Hawk and love it. It's winter and very cold up here and have tested it out a few times and it feels great.
The stock carb seemed to run really well in the cold but once the bike started to get really hot, it would go back to being really boggy again just like it did in the summer. Over the summer that's all it ever was. (Again this is referring to the old stock carb) I put the 110 jet on the mikuni because that's what i was recommended. But i see A LOT of people using the 115. I was wondering if i should go up to the 115 or if i will likely need to once it starts to get hotter out? or if i would have to go to the 100. I ride at low altitude. (ive seen people mention high altitudes when referring to the jetting) Also if anyone can give me some info on what a higher or lower number jet does exactly and how i should know which way to go if i start to have problems. I want to have my bike set up for warmer weather since thats when i will be using it the most. and if i run into problems with the jetting i would like to know which direction i should go |
What mods have you done?Also where exactly do you live ,for above sea level elevation.
#3 | |
Not many performance mods. I put on the 17t F sprocket. Opened up the air box. And the Mikuni Carb. Thats about it. I live in OHIO and i think we are about 600ft above sea level. The bike runs great so far in the colder weather, but summers here get into the 80-90+ degrees. and was wondering if i should go with a different jetting. |
You need a fatter jet in colder weather, since the air is more dense. Jet sizes are in millimetres, so a 110 is 1.1mm, a 115 is 1.15mm etc. Before changing jets, evaluate how the engine runs and go from there. Does it fail to idle? Does it bog when you first open the throttle? Does it have a hiccup at mid-throttle? Does it feel like it's running out of gas at WOT? All of these questions need answers before changing jets. A plug chop is also wise.
#5 | |
