10-26-2007, 05:55 PM | #1 |
Hey Mick,
Side-stand spring...
Phil '18 FXBB Softail Street Bob '17 Tacoma TRD |
10-26-2007, 06:26 PM | #2 |
No, it must be the piston spring. Pull the head off and attach the spring to the bottom of the piston to the crank, then re-assemble! Do it QUICK!
1985 Kawasaki Tecate-3 1997 Ural Sportsman 2WD 1980 Yamaha XS1100 2005 TANK Trail 200 2009 Lifan LY110GY-3 (2) |
10-26-2007, 06:46 PM | #3 | |
***Edit*** Congrats on the bike Mick, How does it do so far????
10-28-2007, 10:23 AM | #4 | |
10-28-2007, 07:12 PM | #5 | |
Right-side
10-29-2007, 07:59 AM | #6 |
Do all the Lifans come with the rear end assembly in pieces??
10-29-2007, 12:08 PM | #7 | |
10-29-2007, 10:17 PM | #8 |
The flat piece just connects to one of the headlight fairing bolts.
If you have no power check the mainfuse and then connections. Allen
10-30-2007, 09:06 PM | #9 |
I got a replacement battery on ebay for my hard to find battery on my Shineray...if i remember correctly it was a 12n7a or 12n73a (3b will work too)...anyway...not only did i get one sent for free from powersportsmax...but i also bought one on ebay from this vendor:
http://motors.search.ebay.com/_W0QQsassZmotobatteries Yes...it was very hard to find one...nobody local or anywhere else i tried online had one...but this guy had it... worth a try... 8) |
10-30-2007, 09:07 PM | #10 |
It is an odd size, But You should be able to find one by measurment.
If not try a 9 series battery. That should be close enough in size. An ETX9 seemed to be almost right for these.
10-31-2007, 01:54 PM | #11 |
Dang, A 9 fit mine...Might be a gtx5L-bs or something like that..Should be easy to find.
10-31-2007, 01:56 PM | #12 |
It should start and run without the battery in it at all. That's the way I've been running mine all this summer. I just put some electrical tape over the battery leads. Headlight is a little dim at night but otherwise it runs just fine.
In this cooler weather, I have better luck starting it with a push start on a hill. Where in Central PA are you? I'm in Mechanicsburg right accross the river from Harrisburg.
06 Lifan LF200GY-5 |
10-31-2007, 02:31 PM | #13 | |
2005 Roketa rat bike - The Ratketa 1982 Yamaha Maxim 750 The Ratketa Restoration Project The Ratketa Blog |
10-31-2007, 05:01 PM | #14 |
You might just need to turn the idle up.
Allen
11-27-2007, 03:11 AM | #15 |
Can You Help me out on the rear end?
Hey Mick,
I just got one of these things too. Mine came with rear swing arms bolted to the packing crate and no instructions for the rear disc brake and the spacers go together on the axle bolt. Did you get yours together? Could you tell me the order and the position of the brake? A pic would be great!! Haven't tried to start it yet. I'm hoping I don't share your battery problem. Thanks. Bruce |
