Old 01-14-2017, 12:22 AM   #1
crackerjac   crackerjac is offline
Fork oil?
So I figure I might as well change out the fork oil on this bike as I'm fixing it up. What's the procedure, oil type, and capacity to do this? The bike appears to use the same front forks as a Gio X31 bike. See pic
Old 01-14-2017, 07:18 AM   #2
humanbeing's Avatar
USD http://www.bikebd.com/difference-bet...hock-absorber/ ?
http://www.chinariders.net/showthread.php?t=10266 gave u the genral picture ...
Measure how much oil drained maybe the best answer...
Oil type: ATF , AW32 hydraulic oil works fine in most case
btw. Gio X31 http://gmanmotorsport.ca/gio-x31-250cc.html uses Taiwanese http://www.fastace.com/
Old 01-14-2017, 01:33 PM   #3
Thanks for the reply. Doing a search I can never find any actual info on BSE Bosuer maintenance so I assume what looks to be the same.
I keep reading more and more that these non adjustable forks are not good for most riding and hard on the body.
Can you recommend some reasonably priced adjustable units I can use and what would need to be changed converted? I read something about using YZF or early RM parts as well but nothing confirmed.
These ones I currently have measure 711mm long (quick measurement) by 42mm/48mm but I'm not against changing out the triple clamp if need be, I'd just like to know what I'd have to use. Thanks!
Old 01-14-2017, 09:34 PM   #4
pete   pete is offline
pete's Avatar
711mm yer not going to find anything that short..
maybe just maybe from a small 80/85 MX bike...
really just ride what yer got... save yer coin for
something better..
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 01-14-2017, 09:41 PM   #5
something better..
It's probably a 730mm. Just a quick measurement and I'm sure it was compressed a bit. -30c with windchill I didn't want to be out in the garage any long than necessary, lol.
Old 01-14-2017, 10:02 PM   #6
humanbeing's Avatar
These? http://www.yuanabsorber.com/aspx/def...ssid=69&id=164
Old 01-14-2017, 10:47 PM   #7
pete's Avatar
but they are prob just as nasty as it already has in it..
just a diffrent brand of nasty....
just measured the forks on my bikes.
Honda CR250 around 1000mm "USD"
Husaburg again 1000mm "USD"
TTR250 940mm "normal style forks"
09 XT660R ...
06 TTR250 ...
81 Honda CT110...
