Old 01-13-2017, 05:25 AM   #1
dannymcmeans   dannymcmeans is offline
hisun 800
have a 800 side by side hisun less than 500 miles had in 4 wheel drive once snowed over the weekend went to put it in 4 wheel would not go light just blinks on the dash where do i start cheched the fuses and connections
Old 01-13-2017, 09:28 AM   #2
katoranger's Avatar
Is the 4wd manual shift or electric shift?
Old 01-14-2017, 07:52 AM   #3
electric
Old 01-15-2017, 12:12 AM   #4
Is it still under warranty? Call the place you bought it from or the distributor.
Old 01-15-2017, 09:25 AM   #5
It's not under warranty. We bought it from a local cycle shop that picked it up at auction.
Old 01-15-2017, 12:08 PM   #6
I know that Excalibur Motorsports used to distribute Hisun. Not sure if they will be able to help you out, but couldn't hurt to try?
909-591-8800
Old 01-16-2017, 06:51 PM   #7
Dakados   Dakados is offline
Dakados's Avatar
Electronic can freeze up easily, the most common solution, if no garage to thaw it, is to take a mallet and tap the front diff several times. This while 'rocking' the unit.
Regards,
Dak
