Old 01-01-2017, 10:24 PM   #1
Numbrseven   Numbrseven is offline
Numbrseven's Avatar
Thumbs Up First attempt at pics. Coolster 3150's
The red one is the DX2 and the blue one is the DX3
Old 01-02-2017, 12:50 AM   #2
Merlin   Merlin is offline
Very nice. Well done.
Bashan Blaze
Old 01-02-2017, 04:22 AM   #3
Adjuster's Avatar
Very nice. Are they both big adult sized bikes?
Old 01-02-2017, 07:37 AM   #4
Nice Quads! I noticed the LED head lights. Nice upgrade from my 2014 model I have. I had to change one of the headlight bulbs this weekend. I'll have to see if I can order those headlights for mine.
2004 Honda ST 1300
Old 01-02-2017, 09:02 AM   #5
Nice Bikes!! Great pics too. Those GY6 motors are very dependable!
My Stable- 2022 Lifan KPX250 , 2023 Royal Enfield Himalayan, 1992 Honda GL1500 Goldwing, SSR 70 Auto, Kymco Mongoose 90, Honda Four Trax 300
Old 01-02-2017, 10:22 AM   #6
Numbrseven's Avatar
As far as rider size, I'd say they are about the size of a normal 250-500cc
Old 01-02-2017, 10:24 AM   #7
Numbrseven's Avatar
Those headlights are for looks, they're not very functional. We won't be riding at night much at all except when stalking coyotes and we don't use headlights for that, so no big deal for us.
Old 01-02-2017, 11:27 AM   #8
Thanks for the heads up. The ones on it now do work very well at night. I just figured the LED's would be brighter. So if it ain't broke, don't fix it lol. I may just add some good LED's flood lights instead. We do ride at night.
2004 Honda ST 1300
Old 01-02-2017, 11:37 AM   #9
Yep. Even the LEDS are useless, I hear. I always say, "It's so others can see you coming at night, because you certainly can't see them."
Old 01-04-2017, 08:51 AM   #10
Just noticed you didn't flip the rear wheels. it widens the wheel base and makes it more stable on the curves and sharp turns.
2004 Honda ST 1300
Old 01-04-2017, 07:13 PM   #11
zackattack91   zackattack91 is offline
Would that put your air valve on the inside of the wheels then? Is that what your saying? Just flip the outer to inside?
Old 01-04-2017, 07:23 PM   #12
Darth Racer's Avatar
That is what he is saying. It changes the offset of the rims to your advantage.
Old 01-04-2017, 07:37 PM   #13
Yes that's it
2004 Honda ST 1300
Old 01-04-2017, 10:28 PM   #14
BigWeld   BigWeld is offline
BigWeld's Avatar
It also gives more leverage to the wheels, so beware riding it like a spot quad with the wider stance given by the abnormal offset......who knows how strong those axles are.
Old 01-05-2017, 07:49 AM   #15
What do you mean riding it like a spot quad? If this makes for a better ride and handling, should this just be a routine thing to do on any ATV? Are there any disadvantages or negative effects? Should this be done only on the rear wheels correct. Can't do it to the front because of the drum brakes I'm assuming?
