Old 12-21-2016, 11:10 PM   #1
Progressive Shock - Sag Setting
Today I got my Progressive Suspension 465 installed...and my dogbones lubed up. Now, I want to make sure I have it setup optimally by seeing the preload and rebound. My front and rear rebound seem fine. Comes back fairly quickly but doesn't buck or bounce. But the rear preload is giving me some issues and making me wonder if I'm doing things correctly. So this is on an RX3, I'm a fairly light guy at 120 pounds and then add my riding gear and having all the normal stuff on the bike I first put it up on the center stand and then measured from the center of the axle to a point I marked up on the luggage frame. It measured 21 13/16". My understanding is our bike has 5.7" of rear travel. So setting a 30% race sag means that the measurement with me on the loaded bike should be 20 1/8". I mounted the bike and bounced it a bit to settle the suspension and had my wife measure the same points. It was closer to 19". So turned the preload spring down a couple of turns and was able to get it to 19 1/2". But there was also a note in the supplemental manual for the CSC version that said: Caution: The installed spring length must never be shorter than 8.13" or shock damage may occur. The spring length was shorter than that from the factory and I'm worried about continuing to tighten it. BTW the shock came with the light spring.
Any thoughts or suggestions? I plan on calling Gerry tomorrow but wanted some of your in the field recommendations also.
Thanks much!
2017 BMW F800GS Adventure
Old 12-21-2016, 11:50 PM   #2
jbfla   jbfla is offline
Hi Joe,
Here's Spud's tutorial:
http://www.chinariders.net/showthrea...Shock+absorber
jb
2014 XT 250........
Old 12-21-2016, 11:58 PM   #3
pete   pete is offline
pete's Avatar
heavyer spring required.... Did CSC not ask you for
your weight etc ? if theres one thing I have learnt
yer don't buy suspension componets from motor bike
shops..
But the sag setting you are trying for
are for a 100% off road.. with these setting
the bike will wollow though the corners...
if I was you I would set the sags somewhere
between dirt & road....more along the lines
of a motard set up......
yer never said what the static sag is...
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 12-22-2016, 09:33 AM   #4
First, it's much more accurate to measure suspension setup in mm rather than in inches. You are looking for 1.7 in of sag....hard to keep track of that when you are forced to deal with fractions of an inch.
The caution you mention is probably due to the limited travel of the OEM shock. The Progressive Suspension likely has much more travel. I'd recommend riding the bike as it is now. See how it feels to you. If you are happy with the ride that's all that counts. Remember, that 30% figure is just a starting point.
Peter Y.
Old 12-22-2016, 04:29 PM   #5
Pete, I requested the light spring which is now default on that shock since I weigh 120 pounds and others on this forum had mentioned it. I am setting the shock up for offroad riding right now as I do a lot of that. I'll stiffen it up come summer as I start moto camping and loading it up a bit more. The static sag of the bike is 20 9/16". That was with the hard luggage and gear in them. Just not me on the bike.
I usually do MM but since I setup a wooden yardstick to allow me to easily see the sag I ended up using inches. It wasn't much of a stretch to do the conversion of 1.7 to inches.
I spoke with Gerry at CSC this morning about the shock setup. Specifically I wanted to ask about the little add-on sheet that was included by the manufacture that spoke about not having the spring set shorter than 8.13" and that from the factory it came at about 7 1/2". He said that should not have been included for this shock and to ignore.
I took the bike out on some nice twisties and some bumpy fire road to test out the shock. I like it. It seems set well for both and doesn't buck around like the OEM one did offroad and doesn't wallow in the turn...felt confident railing around!
As always, thanks for your comments and pointers and have a great holiday!!!
Old 12-22-2016, 08:47 PM   #6
Interesting that the light shock spring is now the default. Thanks for that update. When I got mine they assured me that the existing spring was perfect...not so to me...I asked for something lighter. That appears to now be the standard. Funny how these things work out. Once you get the suspension dialed in the bike is much more fun...as you have shown. Enjoy.
Peter Y.
Old 12-24-2016, 05:55 AM   #7
Dualsport Chic   Dualsport Chic is offline
Dualsport Chic's Avatar
Interesting indeed - as I was told the 450 shock was the right one for me by CSC at only 140 lbs - only later to come to find that it is far too stiff for my weight. Feels like I am going down the road without suspension much of the time if the terrain is bumpy. I may opt for the lighter spring as well - just have to see how folks like it once they've put some miles on it. I tried calling Progressive but they did not seem to know that the 450 spring CSC sold me existed and never called me back after they were going to 'research it'. Will put more time and effort into it come Spring once the snow melts.
Carpe Diem
IBA#65836
2005 BMW F650gs
2008 Yamaha XT250
2013 Yamaha XT250
2009 Suzuki Gladius
Old 12-24-2016, 01:12 PM   #8
rjmorel   rjmorel is offline
rjmorel's Avatar
DSchic, I had the 450 spring and went to the lighter one also . More better and I'm around 185lbs geared up. rj
Live Zong, and Prosper
Old 12-24-2016, 01:54 PM   #9
Same here, rj.
450 spring too stiff for my geared up 190#.
I'll have to live with it...not spending any more $ on this "inexpensive" bike.
jb
2014 XT 250........
Old 12-24-2016, 02:53 PM   #10
pete's Avatar
Is the 450 spring 4.50nm/mm ?
Or do they tell yer the nm/mm rating..
but 4.5nm/mm seems very soft so it makes me
think the 450 is meaningless number...
Or if someone could measure there spring
i could run the numbers though a spring calc
to fined out what it is.....
uncompressed length = ?
fully compressed length = ?
number of active coils = ?
out side dia = ?
wire dia = ?
09 XT660R ...
06 TTR250 ...
81 Honda CT110...
Old 12-24-2016, 05:13 PM   #11
Jay In Milpitas's Avatar
No, Pete, that's 450 lbs./inch.
I don't know what Progressive was thinking when they chose that spring.
Old 12-25-2016, 07:05 AM   #12
But moreover - what was CSC thinking selling that 450 spring to a 140 lb rider when I expressly asked them if it would work for a lighter rider?? I am told that this spring is used on Goldwings - REALLY???? This is my beef.
Carpe Diem
IBA#65836
2005 BMW F650gs
2008 Yamaha XT250
2013 Yamaha XT250
2009 Suzuki Gladius
Old 12-25-2016, 07:07 AM   #13
RJ - can you shoot me the information on the new spring you acquired - I need to find it and buy it to save my fragile back.
Carpe Diem
IBA#65836
2005 BMW F650gs
2008 Yamaha XT250
2013 Yamaha XT250
2009 Suzuki Gladius
Old 12-25-2016, 11:57 AM   #14
Inroads   Inroads is offline
My shock spring is a 375/465 that I received last week.
Seems to be in the ball park for my 190 lbs.
Old 12-25-2016, 03:42 PM   #15
mine is labeled 1156 375/465, it works for me @ 195 lbs. You can check the Progressive web site for springs that fit on our shock. You'll have to pay attention to the spring length, get something close to the 1156 so it is matched to the range of our shock.
Peter Y.
preload, progressive suspension, sag, shock
