Old 10-18-2007, 09:11 PM   #1
jtm087   jtm087 is offline
Hensim 150 starting issue
My hensim 150 will only start up with the choke all the way up, then when riding with the choke up it wont go faster than like 10mph then struggles, but works fine when choke it changed down to middle or low... wheat could be the problem??
Old 10-18-2007, 09:20 PM   #2
Q   Q is offline
Clogged carb.
Q
Old 10-18-2007, 09:36 PM   #3
ambassador   ambassador is offline
The choke is only used to get the bike started, once it gets warmed up there sould be no need for it, you don't ride with the choke on...
Is this your first bike?
06 Lifan 200 GY-5
Old 10-19-2007, 08:37 PM   #4
yea this is my first bike, but yea I never gtouched the choke until I had this issue with starting it, someone recommended that I try adjusting the choke which worked, but I didnt have to do that b4, but I will try cleaning the carb
Old 10-22-2007, 09:50 PM   #5
panterra_rider   panterra_rider is offline
I have the same bike. I start with choke on full - even in warm weather. But, that said, I throw it down pretty quick after that and start my ride or else it bogs (too much fuel from the choke).
I've gone riding lately in about +5 Celsius weather and the choke works like it's supposed to - IMHO, I think you're bike is probably fine.
Cheers,
Rian
2 Hensim-built 150cc dirtbikes (Panterra branded)
Kazuma 110cc Lacoste quad
Old 10-23-2007, 12:31 AM   #6
thanks pentera-rider, i was just wondering b/c i never had to do it before and it seemed kinda odd that out of the blue this would pop up, but i cleaned the air filter and carb, it runs a lot smoother but I still have to adjust the choke on inital startup
Old 11-11-2007, 11:35 AM   #7
even the jap. bikes I've owned with kickstart have always required a little bit of fiddling ...I kind of like it that way but I'll admit my wife would've been better off with electric start. Oh well...
R.
