Old 11-15-2016, 09:39 AM   #1
Dannyc99   Dannyc99 is offline
My Second Chinese ATV Better mods
I liked the cvt cooler on the red one so this time I went a little crazy
CVT AND CARB SNORKEL
Breather lines and vent lines ran higer
12" RIMS 25" TIRES
New CARB
Wheel Spacers front and rear
Anyone Know what size Rear sprocket I should go to?
48tooth?
What size front
I know it may not work as a plow but wanted to try lol.
Old 11-15-2016, 11:34 AM   #2
I like the snorkel idea. Interesting idea to combine the cool air for the CVT with the fresh air for the intake.
Old 11-15-2016, 11:36 AM   #3
Here was the thought process.....The Varaitor is sucking in air so that should help to make sure there is enough for the Carb. I'm 50/50 on the filter so far. I seem to have a slight bog on throttle. I replaced the plug so I can see the color change in a few days. I almost think I'm running rich, which isn't the worst problem to have but I may not be getting enough air to lean it out.
Old 11-15-2016, 12:20 PM   #4
Adjuster's Avatar
I like the minimal plastics. Did you trim the plastics or is that factory?
Old 11-15-2016, 12:24 PM   #5
Its trimmed
Old 11-16-2016, 11:28 AM   #6
If you can figure out how to attach your blade hardware to the rear axle, you'll have an easier time plowing. The blade support bar for a quad is typically quite long; you drive over it and connect it to the rear axle. That way, when you encounter resistance, the front wheels will unload and the rears will dig in. When the blade is mounted under the front suspension, the opposite effect occurs.
