11-10-2016, 12:35 AM | #1 |
she is a cold natured witch
this hawk is very cold natured to get going. full choke and you still have to hold throttle open or it dies then after 3 minutes or so you can go to half choke but still have to give it a little throttle. takes 10 minutes to idle on its own without choke. is this just needing to adjust the hidden mixture screw.
11-10-2016, 12:37 AM | #2 | |
11-10-2016, 06:41 AM | #3 |
All of what Merlin suggests are valuable suggestions. I would also check the head to carburetor nuts. If there is an air leak on the intake side, it could cause these problems.
11-10-2016, 06:52 AM | #4 |
Yes, mine were loose. all 4 carb to intake and intake to head, not sure that's what fixed it, but with the mixture screw turned out to 1.5 and the bolts tightened it idles a lot better and faster warm up.
11-10-2016, 07:55 AM | #5 |
Mine was the same way. Once I turned out the idle mixture screw 1 1/2 turns and shim the needle with 2 washers it starts and idles without the choke. It's been warm here. I sure once it gets cold I will need to choke it.
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 11-10-2016 at 01:08 PM. |
11-10-2016, 08:38 AM | #7 |
11-10-2016, 07:53 PM | #9 |
i ordered jets and a 17t spocket ought to be close to breakin by the time they get here. thanks for the replies
