Old 11-04-2016, 01:49 AM   #1
Merlin   Merlin is offline
Question Bashan Blaze cant get past 7000 rpm?
For the first time I took my Blaze onto the main hi way. I opened it up to WOT for a few seconds and I could not get it past 7000 rpm or 55 mph? (gps) At close to 7000 rpm or WOT the engine would start to sputter. If I let off WOT a very small amount it would smooth out. I have 350 miles on the bike. Iam at over 8500 feet and the bike runs fine at all other rpm's. This carb has no air gas mixture screw. Should I adjust the clip on the needle? Iam thinking of getting a new carb with a air gas screw and a new muffler?
For me other then riding the bike this is the fun part.
Old 11-04-2016, 07:54 AM   #2
If its like the Hawk you will need to change the main jet out to a larger jet. It's running to lean. My hawk was the same way. It had a 98 and I put a 110 jet. Made a huge difference in top end.
2004 Honda ST 1300
Old 11-04-2016, 11:45 AM   #3
I suspect you'll find a pilot mixture screw on the underside of the carb, right where it meets the intake tube. If you feel the bowl, you'll note that there is a relief that accommodates the screw. It is a bear to get at.
That said, it isn't likely to resolve your issue. As Jerry pointed out, you need a bigger main jet. When it comes to swapping jets, I prefer to also swap to a Mikuni, since finding jets is much easier and cheaper. A new Mikuni can be had for less than $40 shipped.
To respond to your other question, moving the clip will affect mid-range, not WOT.
Old 11-04-2016, 11:49 AM   #4
The Mikuni jets will fit the stock Hawk carburetor. I got them from Amazon. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
2004 Honda ST 1300
Old 11-04-2016, 11:50 AM   #5
I wonder if it will fit my carb? Do you know what carb the Hawk has?
Old 11-04-2016, 11:53 AM   #6
2004 Honda ST 1300
Old 11-04-2016, 11:54 AM   #7
Thanks Ill check my carb.
Old 11-04-2016, 11:55 AM   #8
Your welcome
2004 Honda ST 1300
Old 11-04-2016, 10:46 PM   #9
Ariel Red Hunter's Avatar
Keihan
Old 11-04-2016, 10:52 PM   #10
I'm not sure which engine is in the Blaze. If it is the push rod one, it is like the Hawk. What you describe sounds like the main jet is too lean. By the way, congrats on fixing all the problems you had with your bike.
Old 11-04-2016, 11:19 PM   #11
The engine in the Blaze is a push rod counter balance one.
I havent fixed them all. Iam running on my old rear steel wheel with the hub fixed with washers. I got a new set of aluminum wheels from Taobao but the rear wheel cant be used as one nipple will not tighten. Iam waiting on new nipples and spokes from china. Other wise Ive fixed nothing. Never got even one part from the dealer I bought the bike from (superiorpowersports.com). The wheels are the only part I could find. I think Ill just have to make due with what Ive got and do my best to make it a good bike. Ill keep looking for the parts but for now its time for a new carb and muffler. I already have a new longer shift lever.
Old 11-05-2016, 06:01 PM   #12
Please explain the nipple problem more fully. Did it pull through the rim? Wasn't there a problem with the rear hub? You re-did the bad frame welds?
Old 11-05-2016, 08:21 PM   #13
humanbeing's Avatar
The Mikuni jets will fit the stock Hawk carburetor...
[Main jet]
# system is different http://www.jetsrus.com/FAQs/FAQ_miku...ihin_sizes.htm
Different thread pitch: Keihin .8mm vs Mikuni .75mm
NEVER try fit any Keihin jet on Mikuni. The carb will destroyed in no time.
Old 11-05-2016, 09:10 PM   #14
Are these 40 dollar Mikuni VM26's Knockoffs from China? Because from my search a genuine Mikuni VM26 is about 90 bucks.
Old 11-05-2016, 09:48 PM   #15
Never redid the frame welds. Iam getting some practice welding with my tig before I try it. I bought a new set of aluminum wheels. There seems to be a stripped nipple on the new rear wheel. It keeps turning but never gets tight. They are sending me 10 new spokes and 10 new nipples. I bought a new set of 4mm spokes from the same people hoping they will fix my old wheel. The hub for the old wheel was made for 4mm spokes but Bashan used 3.5mm spokes. The new wheel has the same hub but with 4mm spokes and they are not pulling through.
Thank you for asking.
