Old 10-19-2016, 05:11 PM   #1
jbfla   jbfla is offline
Oil Change #8
I think I would have it down to a 15 minute oil change if it weren't for the drain time.
This is the oil change that I plugged the air box and vented the crankcase directly to the atmosphere.
Sample will be sent to Blackstone for analysis.
The drain plug had only a small bit of particles on it, and the oil filter had no sign of sparkly bits.
I've used seven of the paper oil filters, and now will change to the re-usable metal mesh filter:
I also restored the OCS to its original configuration:
Then cleaned the crud off the inside of counter sprocket cover:
jb
2014 XT 250........
