Old 09-24-2016, 04:48 PM   #1
surfndirt   surfndirt is offline
surfndirt's Avatar
Aftermarket (Cheap) 12V / USB for dash?
Anyone know of or a way to rig up a 12V cig. adapter and usb charging ports through the rx3 dash plugs? I'm aware of the $100 option through CSC...that just seems so steep. Anything out there that's not difficult to connect?
'16 Red RX3, K270's, 13t Front, Fog lights, Tusk Bar Risers (4K mi.)
'82 Suzuki SP250 (11k Miles)
'85 Honda Rebel 250 (Sold April 2016)
Old 09-24-2016, 09:33 PM   #2
CSaddict   CSaddict is offline
CSaddict's Avatar
I purchased a cell mount and 5 volt usb combo on ebay and it works so well I bought a second for my street bike.
Look at this on eBay http://www.ebay.com/itm/121863127170
2016 CSC RX3 Ginger Edition
Check out my blog here:
https://www.facebook.com/My-CSC-Zong...0302595973417/
Old 09-24-2016, 11:48 PM   #3
This is what I ordered for mine: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Handlebar mount with cig adapter and 2 USB 2.1a outlets. It's cable has a fuse on it so I'm going to connect it directly to the battery. It has an on/off switch built in so I can continue charging a device when the bike is off or turn off the power to save the battery. Seemed reasonable for $20
2017 BMW F800GS Adventure
Old 09-25-2016, 09:34 AM   #4
The cigarette lighter plugs have one major fault, they do not grab the plug tightly. As a result the plug will tend to vibrate loose. You can convert over to the Powerlet style which will be much more secure.
http://www.powerlet.com/products
I have the CSC dash outlets and made an adapter to mount a powerlet socket in the cigarette outlet hole. For low draw electrical gear this works just fine. If you are powering heated gear the OEM wiring probably won't carry enough amps so a dedicated circuit going to the battery is a better way to go.
a fuze block helps insure adequate amps for extra stuff.
Old 10-19-2016, 02:34 AM   #5
I remember your excellent post regarding the powerlet adapter. Will you please refresh our memories, and provide a link to the post?
