Old 09-10-2016, 02:52 PM   #1
Nithious   Nithious is offline
Nithious's Avatar
Send a message via MSN to Nithious
Hawk sprockets for street
I am probably going to be using my Hawk 95% on street what is the best street sprocket setup? Right now I have a 17t front I wasn't sure about the rear. ( I have no hills on my commute to work or most my joy rides)
Old 09-10-2016, 03:04 PM   #2
Eldric1   Eldric1 is offline
Weight of rider seems like it matters. Most popular is 17/45 but that would not work well for me.
Old 09-10-2016, 04:35 PM   #3
Ariel Red Hunter's Avatar
Maybe 16-45?
Old 09-10-2016, 05:25 PM   #4
Nithious's Avatar
What rear sprocket pairs with 17t front?
Old 09-10-2016, 08:18 PM   #5
chuck   chuck is offline
17t-39 if you weigh less than 180 pounds over I say 17t-42t.
Old 09-10-2016, 08:24 PM   #6
Azhule   Azhule is offline
17t - 43t (over a 42t) or a 17t - 39t combo will save some excess ware on the chain and sprockets (if your chain has even number of links)
Old 09-12-2016, 09:59 AM   #7
Fame28   Fame28 is offline
The 17-45 combo is very common swap for the Hawks. I have it on mine and it just about the perfect setup for the road. If you go too low of a rear sprocket the motor won't have enough horsepower to move it along at the higher speeds with enough torque and the motor will be lugging... The 17/45 combo requires the removal of two links on the chain. I would very highly recommend just ordering a good chain when you replace the sprockets. The chains on these bikes from the factory stretch a lot. Also important info would be to make sure you have a not cheap set of snap ring pliers. The rear snap ring on the back wheel to change the hub is super strong and almost impossible to remove without a good set. A final recommendation would be to use a little loctite on the rear bolts when reinstalling (which you should do on every single bolt on these bikes.
Old 09-12-2016, 06:48 PM   #8
Nithious's Avatar
Haha yeah I notice a few bolts got a bit loose, I been trying to get them all with loctide the removable kind. Can you you please send me a link for the rear 45 sprocket?
Old 09-13-2016, 08:43 AM   #9
wilserchinarider   wilserchinarider is offline
https://www.amazon.com/JT-Sprockets-.../dp/B0068O5W3M
I have a 45 rear now and am thinking the 42t may be better for me
https://www.amazon.com/JT-Sprockets-.../dp/B0068O5N5Y
Old 09-18-2016, 05:20 PM   #10
210hawk?   210hawk? is offline
What are some of y'all's weights sprocket size and top end speed at? New to the hawk haven't bought one yet 55mph top is definitely a deal breaker
Old 09-18-2016, 06:57 PM   #11
Nithious's Avatar
I been like maybe 55ish tops stock but it's very very torque but once I change sprocket that I have already 17t and 45t from what I hear it can hit 65+ but don't quote me on that. To me this is just a good commute/fun bike around town and off-roading no highway.
Old 09-25-2016, 06:53 PM   #12
Nithious's Avatar
So my chain seems to be really really tight and I have no leeway to get it any looser with my 17t front sprocket, is that normal with the 17t 50t combo?
Old 09-25-2016, 07:43 PM   #13
Running 17t with stock rear. Chain is not too tight. How many miles does you have on it? 235lbs runs 60mph easily except hills of course.
Old 09-25-2016, 07:49 PM   #14
Republic   Republic is offline
My chain was too tight to run 17 with the stock 50 rear, I run a 17/45 now. It cruises well at 50 but tops out less than 60 right now with everything stock.
Old 09-25-2016, 08:30 PM   #15
fredweb   fredweb is offline
Odd
If you are topping out at 60 with taller gears then you obviously have not gotten the carb and valves set properly. I am running stock gearing and i can push 70+. I would get the carb and valves set properly before doing any more gearing. i bet you are running way too lean. Does it buck at high rpm?
