Old 08-26-2016, 08:35 PM   #1
vicbarber   vicbarber is offline
hawk 250 won't turn on brand new
just purchased a hawk 250, i assembled it yesterday and was able to turn it on, i came back today after work to turn it on again and nothing, changed the spark plug to an ngk spark plug that was on this page, and still nothing, i don't know what to do now
Old 08-26-2016, 09:03 PM   #2
Bruce's   Bruce's is offline
you will have to post what is and isn't happening so me and the other gang bangers around here can understand .What does "won't turn on " mean exactly ?does any lights go on ?does it sound like the starter is turning when you push the starter button ? Or did it just say either good night ,or more than likely nothing at all ,then turn its back on you and go to sleep ?
Old 08-26-2016, 09:06 PM   #3
chuck   chuck is offline
Pull the clutch in before hitting the starter button.Sometimes mine shows it's in neutral on the dash but it's not.
Old 08-26-2016, 09:18 PM   #4
hertz9753's Avatar
Kill switch is my first thought.
Old 08-27-2016, 12:00 AM   #5
Azhule   Azhule is offline
What's the battery voltage?
Old 08-27-2016, 04:21 AM   #6
I put the key in and hit the start button and the starter turns the engine over but it won't fire up, it has had because I took the plug out and it's wet. Bike has less than 10 miles on it, it cranks but doesn't turn on, battery died so I jumped it with my truck turned off
Old 08-27-2016, 10:55 AM   #7
https://www.kazumaracing.com/trouble...s-p-13392.html
http://www.buggydepot.com/tech-cente...uide-no-spark/
Kill switch check ?
Old 08-27-2016, 11:02 AM   #8
Is there anything else I should be looking for on the kill switch besides it being up or down?
Old 08-27-2016, 11:22 AM   #9
Do you have a meter ?you can disconnect the wires and check for continuity .I don't specifically know the hawk ,does it have a kick stand switch? Is the bike in neutral ? Have you tried kick starting the bike?
Old 08-27-2016, 11:42 AM   #10
Have you tried kick-starting it?
Old 08-27-2016, 03:56 PM   #11
BigDoug   BigDoug is offline
Can you short out the starter solenoid to get it to crank?
Old 08-27-2016, 04:07 PM   #12
Re-reading his second post ,the car does crank ,has fuel ,and probably no spark .He needs to help us help him at this point .
Old 08-28-2016, 05:56 PM   #13
I once had an old Jetmoto enduro that came with a 200cc Zongshen engine. Had the same issues and it turned out to be a fouled spark plug. I would change the plug to begin.
Old 08-28-2016, 06:37 PM   #14
motorcyclelove   motorcyclelove is offline
He probably figured it out and we will never hear from him again on what the cause was which sucks.
Old 08-29-2016, 01:31 PM   #15
it does not have a kick stand switch, the bike is in neutral, and i have tried to kickstart it, still nothing
