08-16-2016, 09:50 PM | #1 |
Low Buck AC For My Garage
Because I was whining about the awful heat this past week, Weldandgrind posted a Youtube video on how to make a really cheap AC unit. Well, I made one and after a hiccup or two, it works. Of course, I had to make it my own and did things just a bit differently.
Behold, the Wheezy Green Cheesy Breeze Machine. The bugger consists of an old Coleman 48 qt cooler, two 2" 45* PVC elbows, two 2" PVC couplers, two Delco style plugs, a 12v 1.5a fan, a project box, a switch, a 12v 3a power supply, and a whack of zip ties. I didn't take pics of the build because "I was making it up as I go". As such, I wasn't even sure it would work. But here is why I used the 45* elbows and couplers. The couplers fit tightly into the drink holders located in the lid. I added some RTV to keep them in place. The elbows slip in the couplers and I can move them where I want. I didn't have a lot of ice available for a major test but I did have enough to see that it will work. Temp in the garage. This was actually comfortable compared to the past few weeks. After a few minutes run time. After I got smart and opened the bag, then let the fan blow directly on the ice. With hindsight being 20/20, I would have not used the Delco plugs and, instead, would have installed an 'M' style 5mm female jack in the switch box. I could have just plugged the power supply into the box. Too soon old, too late smart. I'll pick up a 5lb bag of ice tomorrow, close up the garage, let it run for a few hours and see if it cools things down a smidge.
08-16-2016, 10:53 PM | #2 |
Glad you have something figured out ,the swamp cooler is a neat item to play with ,they work great in a tent too .
08-16-2016, 11:00 PM | #3 |
Very cool! LOL I said a funny.
Just curious why the 12v fan, switch and other doodads as opposed to a regular 110 fan with a switch on the back of it? Planning on using it out on the road? / |
08-16-2016, 11:01 PM | #4 |
By the way see if you can find someone that sells block ice or even better dry ice. Our local grocery store Publix sells all types of ice.
08-17-2016, 02:03 AM | #5 |
What I would worry about is humidity build up and rust on tools. I insulated my garage minimumly and stuffed a elcheepo Walmart 5000btu unit thru the wall at the 6ft level. Don't use it much but it does a nice job for its size.
The humidity right now in ar. Is horrible. I have a 20" oscillating fan upside down off the ceiling running 24/7 to protect a mini lathe, micro mill, and all the tools that go with them. If the humidity settles it going to ruin stuff even with oil coating. Last year it took a long time to remove light surface rust and too lazy to do it this year. |
08-17-2016, 07:59 AM | #6 | |
Second reason is to be able to use it in our camper. If 110V is available, I just plug the power supply into the lone outlet in the camper. If 110 isn't available, I can plug into the 12V supply. jct-The thought had crossed my mind, but I've had 21 years of Great Lakes summer humidity here and nary a problem with rust on the tools. But I will keep an eye on things just in case this thing tips the balance.
08-17-2016, 11:47 AM | #8 |
I like the adjustable elbows! Every time I see one of these on the 'net, I learn something new.
X2 on Adjuster's suggestion of block ice.
08-17-2016, 11:52 AM | #9 |
If humidity becomes a problem, you can capture it with calcium chloride; it's a trick I use in my trailer in the winter.
Just pick up a colander / strainer at the local dollar store, and find a pail that it can sit on (I found a small mop bucket at the dollar store that worked perfectly). Pour some generic calcium chloride into the colander, and moisture will be trapped and directed into the pail. Dri-Z-Air is the commercial stuff, but I get the generic version for cheap at the local RV place.
08-18-2016, 06:53 AM | #10 |
First real test last night.
It did not cool down the garage after three hours. It did, however, keep the area I was working in comfortable. That's what counts. Had I used a 22lb bag of ice, or blocks, instead of a 7lb bag, I'm sure the results would have been different. I'm happy.
08-28-2016, 11:20 PM | #11 | |
08-30-2016, 11:28 AM | #12 |
you guys like it cold! at least your summer is short! i think 25-30 degrees celsius are okay...
1971 Garelli Gulp 50cc with open ports and 16 mm Bing Carbie + 1980 Honda XL 223 ZS + 2007 Zongshen LZX200G + DR400SM |
