Old 08-07-2016, 08:51 PM   #1
dhanb   dhanb is offline
2010 Gio Rebel T3 - Ball Joints
Hey guys! New to this forum, i recently bought a used 2010 gio rebel t3, 200cc.
After riding for a bit i noticed significant play from both lower ball joints, went on to figure out that these ball joints are apparently a part of the control arms themselves. Unfortunately i cannot find the lower control arms for the t3 absolutely anywhere, any recommendations?
Thank you!
Old 08-08-2016, 11:48 AM   #2
Welcome!
With some generic eBay searches (like atv ball joint or atv arm), you might get lucky. Otherwise, you might need to grind those joints out of the arms and install replacements that bolt in.
Old 08-08-2016, 12:57 PM   #3
i've tried the above generic searches to no avail, i think I'll have to resort to grinding the joints out of the arms at this point
Old 08-12-2016, 09:04 PM   #4
I suppose i would grind off those welds on either side, take out the joint and install a new one? Any idea where I can find a bolt-on for this?
thanks!!
Old 08-12-2016, 09:37 PM   #5
Bruce's   Bruce's is offline
There is probably no bolt on ,but might get lucky with a snap ring one .Since you have a gio ,I will assume you are in Canada ,you might try looking them up in the Royal distributing catalogue ,but you will need to measure yours up first .
Old 08-13-2016, 07:35 PM   #6
no luck with them unfortunately
Old 08-13-2016, 08:10 PM   #7
What are the dimensions of the old joints ?
Old 08-18-2016, 12:26 AM   #8
gio t 3
Hello.. I am a dealer for gio so I have sent them an email and will let you know if they have them or what to do... I have switch ball joints on a colster before as they say.. grind the out and re -weld them... $$$$ but without it it was worthless.. let you know tomorrow night .... where are you located?????????
ABIBABA ATV ETC
Old 08-18-2016, 08:22 PM   #9
A ARMS from GIO
You are right... no a arms from GIO anymore... the best you can do is to find some ball joints that are about the size of the balljoints once you remove them... have them reamed out and welded into the arms... that is the bad thing about buying some models of GIO,, They quite making the parts and carrying stuff... if you google the maker on ALIBABA or MADE IN CHINA... I think easy vechicle company... they can sent you the parts.. of course they will charge you... and ship DHL it might still be cheaper... I think I paid about $100.00 labour and that was cheap... and them the ball joints...... there is no real way to match them up with some other brand... to much work.. good luck
ABIBABA ATV ETC
Old 08-19-2016, 11:14 AM   #10
With good measurements of the stock ball joints, it shouldn't be that hard to find bolt-in versions with a similar diameter. it would then be a matter of carefully grinding the old joint out and bolting in the new one.
Old 08-19-2016, 12:23 PM   #11
gio t3
does this look like your atv??
ABIBABA ATV ETC
Old 08-19-2016, 12:40 PM   #12
T 3 parts
Just checking my suppliers for these arms to see if they can get them... they are in CHINA so they have access to these companys... will get back to you in a few days with price and shipping... I would get a 4 arms..
ABIBABA ATV ETC
Old 08-19-2016, 10:10 PM   #13
dhand check pm box
Check your pm box.. I emailed you about the arms... from CHINA... THANKS
ABIBABA ATV ETC
Old 08-19-2016, 11:20 PM   #14
thanks!!
I must be missing something but how can the ball joints be welded on? The arms and the welds are orange and the ball joint is bare metal. They should be all the same color if they were welded on right? Try taking off the rubber boot and see if there is snap ring under it. Either way you should be able to then either press or beat the joint out.
http://www.schrems.org/product_info....ducts_id=37978 from A quick google image search for A arm ball joint
2012 Kawasaki Versys
1984 Honda Magna V65
2016 Rhino 250
2016 Tao Tao 125D
Old 08-20-2016, 09:28 AM   #15
Ball joints
Yes they are welded in.......my shipper in China says $110.00 USD for the set....that is cheap....pm me dhand
ABIBABA ATV ETC
