07-28-2016, 07:48 PM | #1 |
Mikuni drain hose wet but not dripping
I never paid any attention to drain hoses in the past, is it normal for them to be wet with fuel but no noticeable dripping. I opened up the drain screw some and held the end of the hose up to see where the fuel level in the carb is and it appears to be almost level with the top of the bowl.
07-28-2016, 09:25 PM | #2 |
funny you mention that, I saw the same on mine and just assumed it was normal. I never see it leaking but almost looks like it's weeping or something.
Hawk 250 with following performance mods: 17t, Mikuni with 110/25, Uni filter, Exhaust. |
07-28-2016, 09:50 PM | #3 |
I wonder if it is just fumes condensing? If a few more say they experience the same thing, it's a safe bet that's exactly what's happening.
07-30-2016, 01:33 PM | #4 | |
07-30-2016, 07:23 PM | #5 |
Normal when going over bumps, but, I'm asking if it is normal when parked?
I'm also curious at what level should the fuel be? As I stated earlier, mine is about even with the top of the bowel. |
07-31-2016, 07:29 AM | #6 |
Normal when parked? Only for a few seconds. The bike is off of vertical when on the side stand. Yes, the fuel level is very high all the time. That's one of the reasons you should turn off the fuel when parking the bike. A little hint ~ If you turn off the fuel before you shut off the engine, it should not drip.
07-31-2016, 02:29 PM | #7 |
Leaks..........probably not in this case but I have had and others also, a leak that is so little that it doesn"t drip but you can smell it in the garage and will empty the gas tank if left alone by itself.
08-01-2016, 06:21 PM | #8 |
Hmmn. This has happened to you with the gas shut off? If so, it is a defective petcock. I have read elsewhere about carb bowl boiling from proximity to hot exhaust pipe. This won't answer the problem of emtying the gas tank. If it is really emptying the gas tank, take out the oil dipstick and smell it for a gasoline odor. If you smell gasoline, don't start the engine. Change the oil before riding again.
08-03-2016, 08:43 AM | #9 |
Mikuni drain hose
A possible reason for Mikuni's to have wet ends on the drain hose, and smell up the garage with gas smells is if the float level is too high. You have to be super careful when changing jets to not in-advertently bend the float arm just that little bit to over fuel the float bowl. When you turn the carb upside down with the float bowl off, measure from the machined ridge on the carb body to the farthest point on the float. Should be between .6 and .66 inch. The little metal plate that touches the needle is where you adjust float height. Take the float out in order to bend the tab. These float and needle and seat parts are very delicate, so be careful.
08-03-2016, 11:17 AM | #11 |
Interesting! I hadn't thought of that.
08-03-2016, 11:42 AM | #12 |
Me neither. But I would run non-ethenol 90 octane, which is easily found around here.
08-03-2016, 02:07 PM | #13 |
I deal a lot with antique moto guzzis, and we find the lighter float trick works well on 40 year old carbs...
08-04-2016, 02:27 PM | #14 |
Yes, and the DellOrto is another great carburetor.
