Old 07-27-2016, 08:03 PM   #1
shanesnofear   shanesnofear is offline
putting my hawk together no spark -_-
Where should I look is there something I missed ?
And i have a new gauge cluster also and have about 2/3 a gallon in the tank and it reads empty still ?
Old 07-27-2016, 08:24 PM   #2
oddthought   oddthought is offline
oddthought's Avatar
Trace the wires back as far as you can, making each connection solid. If something can be unplugged, unplug it and put it back in. Make sure that the battery is connected solidly on both terminals. Ensure that the negative terminal lead is connected to the chassis/engine to provide a good ground.
Previous: '80 KZ550, '04 Shadow 750, '12 NC700X
Current: CSC TT250
Old 07-27-2016, 08:25 PM   #3
w0ss   w0ss is offline
check the kill switch first. The gas gauge is really really bad most say. Mine from the factory showed empty with 2 gallons in it. Might need to bend the wire. Others have said if you fill it up all the way then it starts working.
Hawk 250 with following performance mods: 17t, Mikuni with 110/25, Uni filter, Exhaust.
Old 07-27-2016, 08:41 PM   #4
the gas gauge is actually reading now and ill keep checking but i got zero spark .. I disconnected the green wire too the coil ... I think thats the kill switch ... Kinda sucks I gotta rip it more apart to figure out ...
Old 07-27-2016, 08:41 PM   #5
and it turns no problem just zero spark... would that mean there could still be a bad ground ?
Old 07-27-2016, 09:28 PM   #6
wow few hours of just looking at this thing feeling like a fucking retard ....
wiring ... the black wire has 12 volts going too the cdi ... now this is where shit goes too shit because the wiring diagram seems not right ...
I checked the black white wire coming from the magneto and it did do something on the meter but i am not sure how to test that right ...
the coil seems to be getting zero power from what it seems and I disconnected the green wire too the cdi by removing the pin ... from the wireing that seems to be the ground for the kill switch and no change
Old 07-27-2016, 09:37 PM   #7
firebank   firebank is offline
I put 40 miles on mine and lost spark. Hoping bad magnetic, got one in the mail.
Old 07-27-2016, 09:47 PM   #8
humanbeing's Avatar
1.Stator [Energy/ when] http://chinariders.net/showpost.php?...00&postcount=8
2. CDI http://sanxin.com.cn/Exhibit/exhview.asp?pid=6 | http://sanxin.com.cn/info5/index.asp?id=16
3. Coil http://sanxin.com.cn/info5/index.asp?id=20
Old 07-27-2016, 10:06 PM   #9
humanbeing's Avatar
wiring ... the black wire has 12 volts going too the cdi ... now ...
DC-CDI system ie. Replaced [Red/black] exciter wire from AC-CDI system by +12v (black) in 2-pin connector
Black/white Isn't that a standard color for s/w OFF (trace from the lock...) in AC-CDI (DC system Cut +12V supply)!!!
Old 07-27-2016, 10:20 PM   #10
the cdi is under the seat its not the thing under the gas tank with the fins ?
Old 07-27-2016, 10:55 PM   #11
wow alright so i was testing the voltage regulator lol ..
so what stator runs to the voltage regulator then from there too the cdi thenn too the coil ?
Old 07-27-2016, 11:10 PM   #12
OK i am not sure anymore...
the kill switch runs to the cdi right...
Power should go to the cdi also right ?
Its getting late i been going crazy lol
Old 07-27-2016, 11:17 PM   #13
ok so the 2 plug on the cdi is
black white kill switch ... so thats a ground
and then the other one black red i think it is should have positive power too it right ?
and humanbeing sorry i was so confused i was looking at the wrong part but what do you mean ?
Old 07-27-2016, 11:32 PM   #14
My ac ignition switch wire at the cdi seems to be getting no dc ... specially not 12 volts so I would assume thats my problem ?
Ok its supposed to be AC lol Ic i get 65 volts ac why cranking on the ac ignition wire
Old 07-27-2016, 11:55 PM   #15
Wow i typed a lot ... I learned a few things also lol
Ok CDI stuffs
Trigger ohmed to 150 ohms so thats OK
AC Ignition power 60-65 volts AC so thats OK
OHM'ed out Kill Switch "key off shows ohm / key on shows no ohm" so thats OK
least i am getting closer to the problem
