Old 07-27-2016, 05:06 PM   #1
Merlin   Merlin is offline
Head Scratching Just got a New DB-07k need assembly help (with pic's)
I just got my Bashan Blaze.
Anyone know of a link on how to assemble a Bashan Blaze or a Roketa DB-07k?
There are a few parts that I have no idea what there for? Any clues or hints whould help. I am taking lots of pics. Ill post them later tonight. It seems to be in great shape. Do the decals come off easy? Is there some trick to it? Thanks
Old 07-27-2016, 07:51 PM   #2
Ruined94   Ruined94 is offline
I hear putting acetone on a rag and rubbing the decals works
Old 07-27-2016, 08:22 PM   #3
NM RETIRED GUY   NM RETIRED GUY is offline
NM RETIRED GUY's Avatar
Thumbs Up New Storm
Way to go Merlin can't wait to see your pics.Who did you end up getting it from? There are lots of video's for the Hawk, i don't think the Storm is that much different. Take your time and i'm sure you will get it running.
Old 07-27-2016, 10:56 PM   #4
This is a Bashan Blaze or Roketa DB-07k. I bought it from superior power sports. Ive got most of it figured out. The main thing I could really use at this stage is torque setting for things like axle bolts, swing arms motor mounts all that kind of stuff. Is there a link to these kind of specs?
Old 07-28-2016, 11:51 AM   #5
Pic's
Here are a few pic's. The bike came in good shape. Iam impressed with the fit and finish. Ill post more pics of the build as I go.
Old 07-28-2016, 11:53 AM   #6
Few more. More to come.
Old 07-28-2016, 12:43 PM   #7
nonone   nonone is offline
Brake Fluid works for removing paint and decals whether you want it removed or not.
Old 07-28-2016, 01:32 PM   #8
Azhule   Azhule is offline
Do yourself a favor and buy a proper tool to install the Kick Stand Spring in needed
Will look something similar to this, solid metal T-Handle with a Hook on the end... makes installing the spring a little easier (it will still takes the power of a thousand curse words to install it... but you will bleed from the hands/knuckles a lot less)
Old 07-28-2016, 01:34 PM   #9
The spring comes installed on this bike.
Old 07-28-2016, 01:36 PM   #10
NICE! I have read about a few Bashan's that needed it installed by the customer
Old 07-28-2016, 02:38 PM   #11
katoranger's Avatar
That looks like a pretty standard China bike.
Old 07-29-2016, 12:40 PM   #12
This is my favorite quote on Chinariders of ALL time!!
Old 07-29-2016, 03:18 PM   #13
Head Scratching instrument cluster install help
Hi Can anyone tell me how to bolt up a instrument cluster on my Bashan DB-07k? I cant seem to find a way with out having only one bolt holding the key mechanism and the whole thing tilted? Also the instrument cluster bracket blocks the upper fork bolts so I feel Iam missing something? Can it be installed with both bolts through the key mechanism and with out a tilt? Could anyone with one of these bikes (I think it would be the same with a DB-07) take a pic of how you did it and post it in this thread? If needed I can take pic's to show the problem Iam having. Any advise how to do this would help alot. Thanks
Old 08-03-2016, 09:36 AM   #14
First run of bike gear locked in first and would not come out?
Swapped out the fish oil that came with the bike with good oil. Got the bike started. It got stuck in first gear and would not come out? It felt locked in place. I had to turn off the bike to get it out of gear? With the bike off it came right out of gear? Is this common? Also when I rotate the handlebars to the left the rpms go down and when I rotate to the right the rpms go up. I will try to reroute the cable and nylon tie the cable so it wont move. The bike started right up with the choke on. Warmed up in a few min and ran fine with no bogging with the choke off. Ran it until it was fully warmed up then it got stuck in first so I turned it off and will try to fine tune it today. Seems like a very good bike. I will hook up my tachometer and volt meter today. I will try to hook up the tach to + side of the coil and see how that works.
Old 08-03-2016, 12:04 PM   #15
motorcyclelove   motorcyclelove is offline
keep us updated! I'm trying to decide between your bike, the hawk, or the new
BASHAN bike. Did you figure out how to get those decals off?
