Old 07-22-2016, 08:50 PM   #1
Jayman77   Jayman77 is offline
Jayman77's Avatar
tao tao atm50
Please list all problems I should look for
I have two 2015 models on there way I would like to fix any known issues at assembly
Best engine oil
gear oil
spark plug (with link)
Wiring issues
weak and poor part ( light bulb blinkers brakes)
Anything
2016 TT250
2014 NSS300 FORZA
2014 UN200 BURGMAN
Old 07-22-2016, 10:29 PM   #2
tortoise   tortoise is offline
Originally Posted by Jayman77 View Post
oil
Everyone has their personal preference for various reasons . . suggestion. Synthetics enhance leak odds.
Performance enhancements typically degrade reliability and longevity. If you need to go 40-50mph . . replace with at least a 125cc scooter.
Old 07-23-2016, 04:29 AM   #3
Jayman77's Avatar
Not really looking for performancemod just problems people have experienced they ete for me and my wife in a couple years I might get 250cc so we ca expand our adventures
2016 TT250
2014 NSS300 FORZA
2014 UN200 BURGMAN
Old 07-23-2016, 10:34 AM   #4
Amazon reviews.
Old 07-24-2016, 12:09 AM   #5
Jayman77's Avatar
Thanks I ordered a lot of stuff here and will run through complete pdi apon arival
2016 TT250
2014 NSS300 FORZA
2014 UN200 BURGMAN
Old 07-24-2016, 10:16 AM   #6
Jayman77's Avatar
I watched all those videos and have order all items need
Carb
plug
Plug end
fuel and vacuum lines
clamps
in line fuse
valve stems
fuel filter and peacock
vacuum caps
electric greese
just need a couple of tools I don't have but there is a harbor freight opening right down the sstreet from me so no problems there these are going to be pdi to the max
2016 TT250
2014 NSS300 FORZA
2014 UN200 BURGMAN
Old 07-24-2016, 06:00 PM   #7
Carb
plug
Plug end
clamps
in line fuse
valve stems
vacuum caps
electric greese
Harbor freight down the street uh oh
Old 07-24-2016, 06:29 PM   #8
Jayman77's Avatar
Yea I want be replacing cheap china fuel lines with cheap china fuel lines no noon here
but you can get some things there
2016 TT250
2014 NSS300 FORZA
2014 UN200 BURGMAN
Old 07-25-2016, 02:44 AM   #9
nonone   nonone is offline
I've used this carb with success http://www.ebay.com/itm/271932154574.
I believe it to be a Genuine China factory Keihin.
Everything I've gotten from this seller has been very good. stores.ebay.com/MotopartsSuperstore.
They are the same as these people motopartsmax.com they have better prices on ebay you can look on there website for product reviews a little easier / more detail then feedback selector.
These fuel filters work well http://www.ebay.com/itm/301894639000
These petcocks also work very well and you can't beat the price. http://www.ebay.com/itm/162110637788.
Here is a good no rev limit CDI www.ebay.com/itm/230392879012.
The standard spark plug on GY6's is a NGK C7HSA (4629) I find they are cheaper at the autoparts or cycle store then online ~$2.50.
I always use Gates (USA) fuel lines (~$1.50 a foot at auto store). 2 feet should more then enough. Some people use tygon these things. If you replace the petcock and use clear fuel filter I see no need to use clear hose unless you like the look.
Any conventional 10w-40 or 15w-40 will work for the first 500 KMs. I use Formula Shell or Rotella occasionally Super Tech but any good quality dino oil will work. Use 750ML.
Gear Oil I use 80w-90 or 75w-90 some state 75w-140 (mainly long case) you should have a short case. Synthetic is fine to use from the start on CVT. I've used Valveoline, Mobile, and Super tech; conventional , blend and syn. CVT should take 110ML of gear oil.
You hit the nail on the head about wiring issues. Everyone I've ever put together had some sort of wiring issue some not always obvious from the start. Most of your connections that are problematic are in the front both the front plastic and behind the gauge cluster. There are some more connections when you pull the bucket but in my experience they are normally fine. Sometimes you have to pull the connections apart and get the little fins out on the pins. Ground wire almost always has a problem sometimes you have to re-splice. I would be careful of "extra wires" they normally go places or should go somewhere.
The e-choke / enrichment circuit is almost always problematic from the start You can pull the plastic cover off the e-choke and it will preform much better. Stock jetting on legitimate PD-18J carbs is #33 #85. Around sea level you can turn the #33 out a turn or two and raise the needle and be ok. At 5500 feet they are normally jetting ok if not really close. If you replace the airbox with a pod filter you will most likely have to up jet.
Here are some pilot jets http://www.ebay.com/itm/121943938098
and the Mains www.ebay.com/itm/401099320038
Here are some decent bent valve stems www.ebay.com/itm/371610514231
I've had good luck with 72cc BBK (mixed with 80cc BBK) and CVT mods like sliders and springs. If you want more power I would start with no rev CDI and getting carb tuned. Performance CDIs do nothing but make it hard to start. You should be able to rev to around 11k -11.5k with out issue. Over that piston rings tend to go. Over all they are fun little bikes. You should enjoy yourself on them. The scoot enthusiasts like to say the world is a better place at 25Mph.
Old 07-25-2016, 11:51 AM   #10
Just for clarification . . "Genuine China factory Keihin" is a clone of an actual Keihin which are more expensive. There are probably some differences among the various clone carbs, but most seem to work just fine.
Old 07-25-2016, 12:13 PM   #11
Keihin actually has a factory in China (Nanjing Keihin Carburetor Co., Ltd.). I can't say for sure if it's is coming out of that factory. But is has all the earmarks. So it's either a very good clone or the real deal out of china. Either way It's a very good carb especially at $20.55 shipped.
I haven't been able to find a Japanese one in years. I had a line on some NOS but the guy wanted around $250.
There are a lot of people on these specialty websites claiming Genuine Keinin but I've never seen them produce any documentation. Both the carbs on scooterpartsco are defiantly made in china as is the one I source. The e-choke is different. I can't speak to the quality of either carb you linked. Maybe you can?
I know the one I get has very good castings and micro finishing. The diaphragm is correct and everything is as it should be. The cheap copies use thicker material. It has all the earmarks of a Genuine China Factory Keinin as seen in the thread at 49ccscoot linked above.
I am convinced that the the Chinese put the biggest pieces of junk carbs on the bikes for export (they have to be sealed). I have a scoot that came in with a Kung - Fu carb (I'm not joking). It was to biggest joke you have ever seen. Finishing was terrible and the casting was cracked. It just like the VW German engineers figuring out how to get past our stupid emissions laws and laughing about it. You know somewhere there is Chinese engineer laughing about how they put a Kung Fu on it.
Old 08-01-2016, 05:41 PM   #12
Jayman77's Avatar
Angry
My scoots are here just waiting on drop truck to deliver I was hoping they would be here today maybe tomorrow
2016 TT250
2014 NSS300 FORZA
2014 UN200 BURGMAN
Old 08-02-2016, 05:44 PM   #13
Jayman77's Avatar
Thumbs Up
Got them can not wait for tomorrow to get to work
2016 TT250
2014 NSS300 FORZA
2014 UN200 BURGMAN
Old 12-06-2016, 08:04 PM   #14
Not to be confused with Kun-Fu.
Old 12-06-2016, 08:16 PM   #15
humanbeing's Avatar
Official site: http://www.kunfugroup.com/
