Old 07-06-2016, 12:32 PM   #1
Skyteamst90   Skyteamst90 is offline
Skyteamst90's Avatar
Speaking of rear brakes
I installed a new inner tube on my rear tire from a flat. First time doing this and it went well on this BASHAN STORM. However, when I went to reinstall the rear brakes, the rear brakes no longer work. I re-bled them several times and inspected the lines, no leaks. I verified that the master cylinder is getting fluid to the caliper, but the caliper is not allowing the piston to move. Do you think it is a bad piston/caliper?
On the radar: CSC - TT250
Moto Aventure ride 2020.
"If everyone is thinking the same thing, no one is thinking." Gen. Patton.
-2017 Suzuki SV650
-2015 BASHAN - STORM
Current mods: LED headlight & tail light, LED fog light, JT 428-130 chain, 47t rear sprocket, 4-fuse box, oil-cooler, CSC TT205 hand controls, 32" handlebars, aftermarket 295mm rear shock, digital speedo & tach, USB/12 volt accessory; painted flat-black.
-2005 Skyteam ST90 (sitting in pieces)
-2003 Buell Blast - SOLD
Old 07-06-2016, 09:03 PM   #2
Ariel Red Hunter's Avatar
How did you get the brake pads wide enough to put the brake disc back in?
Old 07-06-2016, 09:11 PM   #3
jet321   jet321 is offline
You may have damaged the caliper piston, or it's stuck.
Old 07-06-2016, 09:32 PM   #4
Oh No
Used a screwed driver to push the pad in a little bit so it would clear.
-2017 Suzuki SV650
Old 07-06-2016, 09:40 PM   #5
Azhule   Azhule is offline
Might be time to take apart the brake caliper and clean/re-lube everything with some AGS Sil-Glyde Brake Lubricant
https://www.amazon.com/AGS-BK4-Brake.../dp/B000CIHTPE
I found it at a local store for a little less than Amazon..
Old 07-06-2016, 11:54 PM   #6
Is the caliper dirty. Is there a rock in there keeping it from actuating? Need to get it off the disk and observe whats the trouble.
Old 07-07-2016, 10:00 AM   #7
Ok I will have to check this out. Thanks for the help and idea.
-2017 Suzuki SV650
Old 07-07-2016, 05:25 PM   #8
Bingo! Something is jammed in there.
Old 07-08-2016, 12:24 PM   #9
I will look at it today. When I was originally looking at it, the piston is pumping, but does not apply pressure to the disk...So I will try to disassemble today and see what I find.
-2017 Suzuki SV650
Old 07-08-2016, 01:36 PM   #10
So I took it apart and it appears to be normal but for some reason this is what is happening. When I pump the pedal to bleed the brakes, their doesn't seem to be pressure building up and the brake pedal goes all the way down. There is fluid in the caliper and no air bubbles. I think it might be a bad system and just need a new caliper or master cylinder. I will just buy one online because trying to warranty this stuff with a dealer is not worth it.
-2017 Suzuki SV650
Old 07-08-2016, 03:50 PM   #11
Here's how I bled the brakes on the China Bike... with the bleed valve closed, pump the lever 4 or 5 times quickly... then with the lever still fully pressed, open and close the bleed valve as fast as you can...
Repeat the process several billion times until everything starts working again
Old 07-08-2016, 05:33 PM   #12
pcspecialist   pcspecialist is offline
I had a somewhat difficult time getting my rear brake to work again after installing a rear brake light banjo bolt pressure switch. I ended up doing similar to Azhule and it worked for me also.
http://www.chinariders.net/showthrea...t=16636&page=2
Old 07-09-2016, 03:44 PM   #13
OK, I misunderstood the problem. What you describe is a classic symptom of air in the system. Bleeding hydraulic disk brakes is much more difficult than bleeding hydraulic drum brakes, because drum brakes require much less pressure to work. So you can have solid fluid in the caliper, but an air bubble furthur up the line. How did the air get in there? Perhaps when you jiggled the brake pads to re-install the wheel. How did the air bubble get up the line? It migrated up there because air is lighter than brake fluid.
Old 07-11-2016, 11:24 AM   #14
Hey thanks for your help. I did the procedure about 15 times and it finally worked and finally bled. I didn't realize it was so much effort to get that air bubble out of it.
Now its on to other mods and fun rides.
-2017 Suzuki SV650
Old 07-11-2016, 01:37 PM   #15
Glad we were able to help. Have fun with your toy.
