I have ordered a exshaust for the tt and would like a cone fillter if it would increase air flow need help
What do you guys think
2016 TT250 2014 NSS300 FORZA 2014 UN200 BURGMAN |
find out what Motocheez is running w his new exhaust setup. he's getting some serious goodness out of his exhaust/mikuni setup on his hawk..
#3 | |
************************************************** *** " Time you enjoy wasting, is not wasted." - John Lennon ![]() “I predict future happiness for Americans, if they can prevent the government from wasting the labors of the people under the pretense of taking care of them.” ― Thomas Jefferson "If you don't know where you're going any road will take you there" ....George Harrison song |
Motocheez is using a mikuni? Nowhere do I find him mention that.
With the airbox mod, I didn't even bother using my Dremel, a box knife works just as well. |
So far, the breather on the TT seems like a good one. It's big and has lots of surface. I know on Q, Boost Crazy tried several mods to the intake and if you have a good breathing box, it made no difference on his dyno having the stock box or a pod filter.
On the TT, I want to ditch the pipe and cat and then do some jetting. That should help a ton.
silly little pod filters hanging on the end of the carb.....
Anyone ever wondered why the bike companys go to all the trouble to put a great big air box in... (it's not just to take up room and make putting the other stuff harder to find room for) ...
#7 | |
A pod filter can make more power if the airbox is restrictive but it won't automatically make more power. In most cases switching to a pod will decrease power unless tuning is properly altered. In many cases switching to a pod will decrease low end power and create a high end surge which feels like an increase in power because there will be a pronounced power band even when the overall power is weaker. |
All good points '16 TT. You pretty much nailed it with the CCV system (for CARB and EPA) along with keeping the filter out of harms way.
I've swapped to pods on many of my CB's....but it was because the original boxes were pure garbage. Even on my new Rhino I just purchased, the original air box was a disposable cylinder with an itty bitty filter in it that was unserviceable. In that case, a pod filter was a vast improvement for both breathing and filtration....and serviceable.
#9 | |
If I had a low flow unserviceable airbox I'd start by trying to modify the box for a better filter, but I'd pod it too if that wasn't doable. Ideally I'd fit a paper filter to it if I could find one that fit. If you still have that unserviceable box and wanna send it to me for a potential hack I'll tinker with it. Most you'll loose is a throw-away part and shipping. |
#10 | |
I know there's tons of conjecture, etc...on K&N filters. That said, I've run them my entire life with spectacular results and very long-lived engines, both 2 and 4 stroke. Like anything else, they need servicing and oiling. In dirt, I've usually run the Uni's back in my MX racing days. All good results....until I had an Uni go up in flames once. That was unnerving. It was a fluke accident though.
