06-13-2016, 02:42 PM | #1 |
Lost exhaust header stud
Does anyone know where I could get the exhaust header stud? While I was riding today one of mine decided it didnt want to be attached to the engine anymore...
Would these work? http://www.ebay.com/itm/1981-Honda-X...1XLSGB&vxp=mtr Thanks. |
06-13-2016, 03:18 PM | #3 |
Y not just get a 8mm bolt?
My YouTube channel where you can check out my hawk and other cool stuff: https://www.youtube.com/c/Andrew93 newrider93 AKA Andrew93 |
06-13-2016, 03:34 PM | #4 |
Ugh, went out to see if the bolt would work and I see it actually just broke off in the head.
Any ideas on how to get that out? |
06-13-2016, 04:28 PM | #6 |
"Alden Tools" (Pro Grabit and or Micro Grabit) works for me every time
https://www.amazon.com/Alden-8440P-G...dp/B001A4CWHO/ or https://www.amazon.com/Alden-4507P-G...dp/B000Q60UOO/ If you have a Menards/Home Depot/Lowes, check those places first, they usually have these extractors in stock for less than Amazon
06-13-2016, 05:13 PM | #7 |
I've had pretty good luck with the "Soak it in WD40 when warm, let it cool overnight, soak it in WD40 again...and get a small pick and try to spin it out" method. Many times they're not buried to the bottom.
Good luck!
06-13-2016, 07:34 PM | #9 |
Thanks everyone for the tips, I ran to the store and got a screw extraction set and it worked perfect.
So thankful, couldve been such a headache. I ran to the store and got a stainless 8.8 bolt and put it in with a lockwasher and washer. So far so good! Thanks again everyone! |
06-13-2016, 08:22 PM | #10 |
Mine did the same exact thing. Same bolt too. I used a M8-1.25 bolt with washer.
